13 Replies Latest reply on Oct 22, 2010 12:36 AM by sri2520ram
    inheritance in VO and binding in dataGrid (updated)
    sri2520ram
      Hi All,
      I'm new to flex and trying to learn a few concepts..
      I'm new using Flex Builder 3 to develop a simple application that displays a Array collection in data grid....
      I have a Value Object called Dept
      package rxr.issuetracker.vo
      import com.adobe.cairngorm.vo.IValueObject;
      [RemoteClass(alias="com.Dept")]
      public class DeptVO implements IValueObject
      public var dept_id:Number;
      public var dept_name:String;
      Another VO is empVO which creates an instance of DeptVO
      [RemoteClass(alias="com.emp")]
      public class empVO implements IValueObject
      public var name:String;
      public var edes:String;
      public var dp:DeptVO;
      I'm trying to implement OOPS in flex...
      I have an ArrayCollection, "arrData" in model class which is bindable...
      package rxr.issuetracker.model
      import com.adobe.cairngorm.model.ModelLocator;
      import mx.collections.ArrayCollection;
      import rxr.issuetracker.vo.*;
      [Bindable]
      public class testModel implements ModelLocator
      private static var modelview:testModel;
      public static function getInstance():testModel
      if(modelview==null)
      modelview=new testModel();
      return modelview;
      public function testModel()
      if(modelview != null)
      throw new Error("only one instance of model can be created");
      public var arrData:ArrayCollection;
      Now i retrieve value from database using spring services as back end..
      I store the value in arrData and using Debug i see that the values are stored as follows:
      model3.arrData
           [0]-rxr.issuetracker.vo.empVO
      • dept_id
      • edes
      • name
      • dp
        • dept_id
        • dept_name
      now i bind this data to dataProvider as follows:
      <mx:DataGrid id="data" dataProvider="{model3.arrData}">
           <mx:columns>
                <mx:DataGridColumn headerText="Column 1" dataField="edes"/>
                <mx:DataGridColumn headerText="Column 2" dataField="name"/>
                <mx:DataGridColumn headerText="Column 3" dataField="dp.dept_id"/>
           </mx:columns>
      </mx:DataGrid>
      here in the output, i get values for edes and name
      but dp.dept_id remains blank...
      how can i bind this inherited data to dataGrid ??
      Message was edited by: sri2520ram
