1. Re: How to Verify using Unit Testing
Michael Labriola Oct 22, 2010 5:43 AM (in response to Praveen Kumar Indupuri)Praveen,
A few issues. First, this is a FlexUnit forum, so I do not know how to help you with ASMock issues. You can certainly post here but I don't know that you will get a response. You will probably need to reach out in an ASMock forum or site for help.
Second, I am not sure that FlexUnit is the right tool for you. This is a unit testing framework, which means testing an isolated unit... generally an isolated class at a time. If you want to see that when an event is dispatched a new screen is displayed, you are looking at dozens to hundreds of classes depending if your project is ActionScript or Flex-based.
If that is the type of testing you are trying to just be sure you really want to try to do this in a unit testing framework. It is going to be much more difficult and probably not suit your needs as well. If you need to test at this high of a level, I would consider more of a functional testing tool such as FlexMonkey or RIATest
Mike
