2 Replies Latest reply on Oct 22, 2010 2:03 AM by eiwah
    unable to open '..\applicaiton.war\flex\libs\fds.swc'
    eiwah
      Hi All,
      I have compilation error of flex project in flex builder .I set up project properties\flex compiler\Additional compiler argument "-services "C:\Adobe\Adobe LiveCycle ES2\jboss\server\lc_turnkey\deploy\commitment.war\WEB-INF\flex\services-config.xml" -locale en_US" . I am using livecycle dataservice 3.1 and eclipse java project jdk 1.5 version also. I want to update my application.mxml file to application.swf file but i can't build successfully and i got error in problem tab " unable to open '..\applicaiton.war\flex\libs\fds.swc".
      Is it related with which part? my import library or my command?
      Anyone will know, please help me how can i build my project as well.
      Ei Wah
        • 1. Re: unable to open '..\applicaiton.war\flex\libs\fds.swc'
          BhaskerChari Level 4
          Check whether the fds.swc exists in your project in this path '..\applicaiton.war\flex\libs\fds.swc".
          Are you using the fds.swc in your project..?? If not using then remove that from Flex Properties>>Flex Build Path >> Library Pathh Tab
          If you are however using it then verify that it exists in your project correctly and that you have given correct relative path.
          Bhasker
          • 2. Re: unable to open '..\applicaiton.war\flex\libs\fds.swc'
            eiwah Level 1
            I have used fds.swc, playerfds.swc ,libs folder ,flex sdk 3 and locale inside the Flex Build Path\Library Path tab. I tried to remove those all except flex sdk. I got the locale en_us error becuase i use that command -services "\foler \file path" -locale en_us command . and i got locale error.
            My colleague built at his presonal computer at his country and he build successful.
            We are the same source code but environment is little different. I used flex builder 3.0.1914 and he used 3.0.2.214193.
            We used the same flex sdk version 3.4.1.100084
            I can't guess why i got that error.
            thanks
            Ei Wah
