3 Replies Latest reply on Oct 22, 2010 7:12 AM by try67
    Layer scripting
    Mar.ko Level 1
      Hi All,
      I have a pdf which is pretty much a guide. I created InDesign file with layers and exported as pdf.
      I'm trying to do the following:
      When user hit one of the navigation links, a layer associated with that link shows up. In layer that showed up, i have more links associated with images in stand alone layers. Everything works like i want.
      The problem is that links in non active layers work behind the scene when i hover over.
      Is there a way to solve this problem?
      The script (in link action) i'm using to show/hide layers is:
      var ocgs = this.getOCGs();
      for (var i=0; i<ocgs.length; i++)
      if (ocgs[i].name == "LayerName")
      ocgs[i].state = ocgs[i].state=true;
      ocgs[i].state = ocgs[i].state=false;
      I'm using Acrobat 9 pro
      Please help
      Thanks in advance
        • 1. Re: Layer scripting
          The last line of each block is not correct.
          It needs to be:
          ocgs[i].state = true;
          and
          • 2. Re: Layer scripting
            Mar.ko Level 1
            Thanks for the answer!
            Do you know how to make link readOnly? When i hit the link, the layer becomes visible and that link becomes readOnly at the same time.
            • 3. Re: Layer scripting
              I don't think a link has such property. Anyway, not one that you can set
              with a script.
              Are you sure it's not covered by something else?
              Come to think of it, you probably are using a form field button, not a
              "real" link. If so, it has a boolean property called readonly which you can
              set yourself.
