3 Replies Latest reply on Oct 25, 2010 9:23 AM by Flex harUI
    Troubles with pipeline and handling events
    mikall1979
      Hi All,
      I need some help to understand why my code doesn't work properly.
      I have an image and I apply on it some trasformations.
      Eg.
      If I click on "rotate" button, the image rotates,
      If I click on "crop" button, I cut the image,
      and so on.
      Now the question.
      I print on screen after every click the size of the actual image state, but the size shown correspond to the size of the previous state!
      Could someone explain me why?
      Below the code:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  private function rotate(img:SWFLoader, angolo:Number):Bitmap
                      var sourceBD:Bitmap = Bitmap(img.content);
                      var m:Matrix = new Matrix();
                      m.rotate(angolo);
                      var targetBD:BitmapData = new BitmapData(img.content.width, img.content.height);
                      targetBD.draw(sourceBD, m);
                      var bitmap:Bitmap = new Bitmap(targetBD);
                      return bitmap;
                  private function crop(img:SWFLoader, startP:Point, endP:Point):Bitmap
                      var sourceBD:BitmapData = Bitmap(img.content).bitmapData;
                      var targetBD:BitmapData = new BitmapData(endP.x - startP.x, endP.y - startP.y);
                      var rect:Rectangle = new Rectangle(startP.x, startP.y, endP.x, endP.y);
                      targetBD.copyPixels(sourceBD, rect, new Point(0,0));
                      return bitmap;
                  private function zoom(img:SWFLoader,width:int, height:int):Bitmap{
                      m.scale(width/img.width, height/img.height);
                      var targetBD:BitmapData = new BitmapData(width, height);
                      return bitmap;
                  private function onBtLoadClick1(evt:Event):void {
                      imageTest.source=rotate(imageTest,0.02);
                      X.text = imageTest.width.toString();
                      Y.text = imageTest.height.toString();
                  private function onBtLoadClick2(evt:Event):void {
                      imageTest.source=zoom(imageTest,300, 400);
                  private function onBtLoadClick3(evt:Event):void {
                      imageTest.source=crop(imageTest,new Point(50,50), new Point(100,100));
          </fx:Script>
          <mx:SWFLoader id="imageTest" x="69" y="93" source="van.jpg"/>
          <s:Button x="183" y="38" label="Rotate" click="onBtLoadClick1(event)"/>
          <s:Button x="360" y="37" label="Resize" click="onBtLoadClick2(event)"/>
          <s:Button x="272" y="38" label="Crop" click="onBtLoadClick3(event)"/>
          <s:Label x="461" y="93" text="Label" id="X"/>
          <s:Label x="461" y="122" text="Label" id="Y"/>
      </s:Application>
      Thank you in advance.
      Michele
