2 Replies Latest reply on Oct 22, 2010 4:24 PM by heywang3
    how to make a variable:
    heywang3
      I am trying to figure out how to make a variable:
      Ex.  I have two fields  feildA  and fieldB
      I want fieldA to be dependant on fieldB
      if  fieldB is  1  then fieldA is 25
      These are all the other variables
      1 = 25
      2 = 30
      3 = 40
      4 = 50
      5 = 65
      6 = 75
      7 = 85
      8 = 95
      9 = 105
      10 =115
      Thanks!!  CJ
        • 1. Re: how to make a variable:
          George_Johnson MVP & Adobe Community Professional
          One way is to set up field A as a calculated field, using a script like the following:
          // Calculate script for field A
          (function () {
              // Set up object to associate values
              var vals = {
                  1: 25,
                  2: 30,
                  3: 40,
                  4: 50,
                  5: 65,
                  6: 75,
                  7: 85,
                  8: 95,
                  9: 105,
                  10: 115
              // Get value of field B
              var v = getField("fieldB").value;
              // Set this field's value based on the value of field B
              if (typeof vals[v] !== "undefined") {
                  event.value = vals[v];
              } else {
                  // If corresponding value is not present, blank this field
                  event.value = "";
          Replace "fieldB" in the code with the actual name of the field you're using.
          You could also use similar code in the Validate event of field B to set the value of field A.
          • 2. Re: how to make a variable:
            heywang3 Level 1
            Works perfectly!!!!
            Thankyou so much!
            I amazed how powerful Acrobat is!
            CJ
