12 Replies Latest reply on Apr 18, 2011 8:33 AM by the_wine_snob
    premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
    Leonardo16
      Dear Adobe Forum,
      I have the following problem, please help:
      I would like to import avi clips in adobe premiere. All clips have the same avi codec. But unfortunately my adobe premiere does not import the sound of a few
      avi clips. It is wired because about 10 out 70 avi clips which have all the same avi codec does not work with sound in premiere CS5. In the timline premiere import the video and audio line but there are no audio waves in the about 10 avi clips. additonally premiere plays the 10 avi clips in the source monitor without sound. Furthermore when I open the 10 avi files without adobe premiere they have sound, but with premiere there are no sound in the 10 avi clips.
      What can I do, so that I can import all avi files with sound. I do not want to convert each of the avi files because then they have not a good quality and it is to complicated and it takes to much time to convert all files in this video project and in the other video project in my future.
      Consequently How can I import all avi files so that they have immediately sound? Do I have to change some premiere settings?
      Thank you in advance
      Leonardo
        • 1. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
          Jeff Bellune Level 5
          Do the problem clips have AC3 audio in them?  Pr doesn't like AC3 audio in AVI files.
          Please post the video and audio codecs that are used in the AVI files.
          -Jeff
          • 2. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
            Work through all of the steps (ideas) listed at http://ppro.wikia.com/wiki/Troubleshooting
            If your problem isn't fixed after you follow all of the steps, report back with ALL OF THE DETAILS asked for in the FINALLY section, the questions at the end of the troubleshooting link... most especially the codec used... see Question 1
            • 3. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
              Colin Brougham Level 6
              What I'm curious about is if these clips are all from the same source; in other words, are these 10 something different or the same as the other 70 that work fine?
              If they're different, a program like VirtualDub could be used to repackage the files by passing through the video (so there is no recompression) and transcoding the audio to a different codec (like PCM audio).
              If they're the same, however, I'd suspect something more like an interrupted audio conform when the clips were originally imported into Premiere. Check the folder where the AVIs are stored; are there CFA and PEK files there with similar names to your AVIs? If so, with Premiere closed, delete all those files and then reopen your project. Watch the yellow bar down in the lower right corner of the application, and wait for it to stop; that's the audio conforming indicator, whereby Premiere is rendering uncompressed versions of the audio contained in your clips. This supposedly results in better playback/editing performance, but if the process is interrupted, you might not have audio in some of your clips.
              Use a program like MediaInfo or GSpot to find out what the codecs used in the clips are.
              • 4. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                Leonardo16 Level 1
                Now I show you details of 2 files:
                the first video clip which you can import with sound (works):
                Video:
                1280 x  720
                data rate: 4259 kBit/s
                total bitrate: 4387 kBit / s
                Single bit rate: 29 single images / second
                Format                           : AVI
                Format/Info                      : Audio Video Interleave
                File size                        : 63.5 MiB
                Duration                         : 2mn 1s
                Overall bit rate                 : 4 388 Kbps
                Format                           : AVC
                Format/Info                      : Advanced Video Codec
                Format profile                   : Main@L4.0
                Format settings, CABAC           : Yes
                Format settings, ReFrames        : 4 frames
                Format settings, GOP             : M=3, N=15
                Codec ID                         : H264
                Duration                         : 2mn 1s
                Bit rate mode                    : Variable
                Bit rate                         : 4 248 Kbps
                Maximum bit rate                 : 4 001 Kbps
                Width                            : 1 280 pixels
                Height                           : 720 pixels
                Display aspect ratio             : 16:9
                Frame rate                       : 29.970 fps
                Color space                      : YUV
                Chroma subsampling               : 4:2:0
                Bit depth                        : 8 bits
                Scan type                        : Progressive
                Bits/(Pixel*Frame)               : 0.154
                Stream size                      : 61.4 MiB (97%)
                Audio:
                Bitrate: 128 kBit/s
                Channels: 2 (stereo)
                sampling rate: 48 kHz
                Format                           : AAC
                Format/Info                      : Advanced Audio Codec
                Format version                   : Version 4
                Format profile                   : LC
                Format settings, SBR             : No
                Codec ID                         : FF
                Duration                         : 2mn 1s
                Bit rate                         : 128 Kbps
                Channel(s)                       : 2 channels
                Channel positions                : Front: L R
                Sampling rate                    : 48.0 KHz
                Stream size                      : 1.85 MiB (3%)
                Alignment                        : Aligned on interleaves
                Interleave, duration             : 21 ms (0.64 video frame)
                the second video clip which you can import without sound (doesn't work with sound):
                Video:
                1280 x  720
                data rate: 4278 kBit/s
                total bitrate: 4406 kBit / s
                Format                           : AVI
                File size                        : 69.3 MiB
                Duration                         : 2mn 11s
                Overall bit rate                 : 4 407 Kbps
                Format                           : AVC
                Codec ID                         : H264
                Duration                         : 2mn 11s
                Bit rate                         : 4 267 Kbps
                Height                           : 720 pixels
                Color space                      : YUV
                Bit depth                        : 8 bits
                Stream size                      : 67.1 MiB (97%)
                Audio:
                Bitrate: 128 kBit/s
                Format                           : AAC
                Format profile                   : LC
                Codec ID                         : FF
                Duration                         : 2mn 11s
                Bit rate                         : 128 Kbps
                Stream size                      : 2.01 MiB (3%)
                Alignment                        : Split accross interleaves
                Consequently, as you can see, they have both nearly the same information
                Both video clips have the following audio codec:
                AAC
                In the folder where all raw video clips exist there are a few new files with the codec ending: .AVD ("the name of the file".AVD)
                But the 2 video clips mentioned above does not have any files like .AVD oder something else like that. But the first one works and the second one doesnt work.
                • 5. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                  Leonardo16 Level 1
                  What is a trouble shooting? I do not understand the website where it is explained.
                  Can somebody explain it to me? How can I do it?
                  • 6. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                    Jim_Simon Level 8
                    There are no cameras that record AVC into AVI files.  Premiere works best when you use standard media you shot yourself using a supported camera.  Other types of media will be hit or miss.  You got a few misses.
                    Your best bet will be to stick to using standard camera media with Premiere, and a consumer editor for other non-standard media from other sources.
                    • 7. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                      Leonardo16 Level 1
                      Pardon, unfortunately I did not understand you. Can you please repeat your sentences again? That would be great.
                      I shot my video clips with a standard HD Cam. Then I upload all video clips from my HD Cam to my computer without converting them.
                      Consequently all video clips have standard codecs. How can I solve the problem? because I would be very very happy when the few video clips works with sound when I pull them in the timeline. I am working on a project and it is almost finished the whole film. But unfortunately that big problem came to me. My film project has to be finished on Monday. So I please you all to help me. Thank you in advance
                      • 8. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                        JaysonM-Y Level 3
                        by monday? boy you're in a jam.
                        why not just convert the audio instead to .wav and then sync em up in premier?
                        • 9. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                          Leonardo16 Level 1
                          Thank you for your idea. But I would like to import the original avi file with sound so that I additionally know how to solve this problem in the future. So please help me.
                          As I said. My whole film project is almost done. I just need to import the about 10 avi clips with sound and then I can export my video. Consequently I think with your help I can do it tomorrow so that my whole film is finished on Monday.
                          • 10. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                            JaysonM-Y Level 3
                            My best advice would be to go with a work around for now.
                            The thread can always continue for you to refer back to when there is a solution, but crunch time is no time to be waiting.
                            Also I sent you a PM
                            • 11. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                              bainofmylife
                              I have had this problem too - I have solved it.
                              I realised that after each capture Premiere has to conform the audio. If you interrupt this process there is no audio for that clip in Premiere (but there is audio if you play the clip in a different program eg Media Player). Never exit the program straight after capture. Look for the yellow bar at the bottom right of the screen.
                              To put this right, exit Premiere, delete the .xmp file for the problem clip, restart Premiere and re-import the clip into the project. Premiere will create a new .xmp file and in doing so it will also conform the audio. Hey presto, the clip has audio!
                              Hope that helps someone.
                              • 12. Re: premiere CS5 import avi clips without sound. How can I import avi clips with sound without convert?
                                the_wine_snob Level 9
                                For more background on the Conforming process, see this ARTICLE.
