1. Re: Set Up AE CS5 for 1.85:1 film 4k
Todd_Kopriva Oct 24, 2010 10:26 PM (in response to l1o1t1r1)That's a rather broad question.
Are you asking about composition settings? Color depth? Other project settings? Color management settings? Memory preferences? Panels and workspaces? What are the details of your computer? How will you be receiving the files? How will you be delivering the files? What are you doing to the footage in After Effects?
2. Re: Set Up AE CS5 for 1.85:1 film 4k
l1o1t1r1 Oct 24, 2010 11:03 PM (in response to l1o1t1r1)OK - I went and open AE CS5 and it says several options so I picked new composition
here is a screen grab.And that took me to Compostion Settings where I could not find 1.85:1 4k - There is one called 4k but after chosing it it appears to be acadmey 4k (I thnik 4:3 ratio)
Here's a screen grabI opened photoshop cs5 to start a background that has to be 1.85:1 ratio 4k. And photoshop did not have the setting for 1.85:1 4k. Then I said to myself ah that should be in AE CS% so I opened it and no 1.85:1 4k. So after seeing that AE CS5 did not have a pre-set for 1.85:1 4k I said you know I better find out how to set that comp up in After Effects cs5. Once I set up the comp in ae cs5 I want to bring the background from photoshop cs5 into ae cs5.
So I would like to get ae cs5 this far - that is create a comp setting for 1.85:1 4k. -
3. Re: Set Up AE CS5 for 1.85:1 film 4k
Todd_Kopriva Oct 24, 2010 11:09 PM (in response to l1o1t1r1)> So I would like to get ae cs5 this far - that is create a comp setting for 1.85:1 4k.
If there's no composition settings preset for what you want to make, then just choose Custom and set the Width and Height values in the Composition Settings dialog box to the width and height of the frames that you'll be work with.
5. Re: Set Up AE CS5 for 1.85:1 film 4k
Todd_Kopriva Oct 24, 2010 11:23 PM (in response to l1o1t1r1)> Kinda confusing to me.
Ask whoever you're delivering the movie to what format and settings they expect from you, and go with that.
6. Re: Set Up AE CS5 for 1.85:1 film 4k
l1o1t1r1 Oct 24, 2010 11:27 PM (in response to l1o1t1r1)Thank You again
7. Re: Set Up AE CS5 for 1.85:1 film 4k
Andrew Yoole Oct 25, 2010 6:02 AM (in response to l1o1t1r1)There's no specific standard. As Todd says, always verify with the transfer company what their required file specs are.
