2 Replies Latest reply on Oct 25, 2010 5:22 AM by SteveHoeg
    H264 footage is pixelating on playback
    cramhead1 Level 1
      Im trying to edit some .mov H264 footage in premioere CS5 but playback in Premiere is always very pixelated. I had to convert the footage using mpeg stream so the footage would work with my pc but playback in Quicktime is fine. Also when I export the footage playback is fine. I cant edit the footage because I can hardly makeout whats going on. If I click propertys in Premiere on the clips im having problems with I get
      File Path: T:\viddy\New folder\493_0560_01.mov
      Type: MPEG Movie
      File Size: 54.5 MB
      Image Size: 1280 x 720
      Pixel Depth: 32
      Frame Rate: 25.00
      Source Audio Format: 48000 Hz - compressed - Stereo
      Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
      Total Duration: 00:00:17:19
      Average Data Rate: 3.1 MB / second
      Pixel Aspect Ratio: 1.0
      in movie inspector I get this
      As you can see Premiere thinks itss MPEG. Could this be the problem? How do I fix this?
      This is what the bad footage looks like
      I have Windows 7, Premiere CS5 5.0.2, Geforce 8400GS, Quicktime 7.6.8, 6 gig RAM, Quad AMD.
      Thanks for any help
