7 Replies Latest reply on Oct 26, 2010 7:42 AM by kglad
    Restrict "Enter, delete and backspace" in TextArea
    A.kameshwaran Level 1
           I want to restrict Delete key, Backspace key,  and Enter Key in TextArea. Please tell me how to restrict these 3 keys. Thanks in advance.
      Regards,
      Kameshwaran A
        • 1. Re: Restrict "Enter, delete and backspace" in TextArea
          use a key listener to do (or undo) what you want.
          • 2. Re: Restrict "Enter, delete and backspace" in TextArea
            Hi Kglad,
                 Thanks for the reply.
            This is my code. Please tell me, how can i restrict it.
            I have named my TextArea as my_txt.
            my_txt.text = "Cuveiro: resteba o restreba 'la segunda cosecha que se coge en un mismo terreno'.";
            listenerObject = new Object();
            // If i press delete key, first  this listener is invoking
            listenerObject.keyDown = function(eventObject){
                trace("keyDown");
                trace(my_txt.text);
            // then this listener is invoking and the delete operation has performed. if i give return false, it is not stoping the delete operation.
            listenerObject.change = function(eventObject){
                 trace("change");
                trace(my_txt.text);
            listenerObject.keyUp = function(eventObject){
                trace("keyUp");
                trace(my_txt.text);
            my_txt.addEventListener("keyDown", listenerObject)
            my_txt.addEventListener("keyUp", listenerObject)
            my_txt.addEventListener("change", listenerObject)
            Please help to restrict the delete,enter and backspace key. Thanks
            Regards,
            Kameshwaran A
            • 3. Re: Restrict "Enter, delete and backspace" in TextArea
              what do you want each of those keys to do?
              • 4. Re: Restrict "Enter, delete and backspace" in TextArea
                For Users, It should not work inside textarea. So that they can't delete or break the line.
                • 5. Re: Restrict "Enter, delete and backspace" in TextArea
                  var origS:String = "Cuveiro: resteba o restreba 'la segunda cosecha que se coge en un mismo terreno'."
                  my_txt.text = origS;
                  listenerObject.keyDown = function(eventObject) {
                      ci = Selection.getCaretIndex();
                  listenerObject.keyUp = function(eventObject) {
                      if(Key.getAscii()==13){
                          my_txt.text=my_txt.text.split("\r").join("");
                      } else if(Key.getAscii()==8 || Key.getAscii()==127){
                          if(prevS){
                              my_txt.text=prevS;
                          } else {
                              my_txt.text=origS
                      prevS = my_txt.text;
                      Selection.setFocus(my_txt);
                      Selection.setSelection(ci,ci)
                  my_txt.addEventListener("keyDown",listenerObject);
                  my_txt.addEventListener("keyUp",listenerObject);
                  • 6. Re: Restrict "Enter, delete and backspace" in TextArea
                    Thank you very much Kglad.
                    Please tell me one more thing for enter key. if already i have multi line text then in that case what i have to do.
                    • 7. Re: Restrict "Enter, delete and backspace" in TextArea
                      use:
                      var origS:String = "Cuveiro: resteba o \nrestreba 'la segunda cosecha que se coge en un mismo terreno'."
                          if(Key.getAscii()==8 || Key.getAscii()==127 || Key.getAscii()==13){
                              if(prevS){
                                  my_txt.text=prevS;
                              } else {
                                  my_txt.text=origS
