2 Replies Latest reply on Oct 26, 2010 2:45 PM by slingsla0
    Setting variables during component initialization
    slingsla0
      I am loading a component which makes a HTTPService call to get data that will then be used to set certain variables in the component.  I make the HTTPService call in an init() function (for the initialization event) and then set the variables according to the data received in the HTTPService result handler.  However, the variables are still null at both the initialize stage and at the creationComplete stage.  If I try and read the variables in a creationComp() function (for the creationComplete event), those variables are still null.  Is this correct?
      I guess I don't understand the flex initialization cycle very well.  When are those variables actually set and available to be used?  I need to manipulate those variables automatically after the component loads.  Is there an event that comes after creationComplete that is appropriate or some other way to approach this?  I am using Flex 3.
