1 Reply Latest reply on Oct 25, 2010 3:40 PM by rtalton
    CheckBox Item Renderer checks wrong grid row after sorting
    iamcootis Level 1
      I have an advanced Data Grid that has a checkBox ItemRenderer. The underlying object being displayed (Server) in the dataGrid is being bound to the checkBox with a selectedForDeployment:Boolean property.
      I had this working just fine until the datagrid is sorted. After the grid is sorted I can click on the checkBox in row 2 and the checkBox in row 8 will be selected for instance. Or in some cases all checkBoxes will become checked. Also, if I have some already checked and then sort, the checkBox will become unchecked.
      I have an example of my itemRender below. Any idea on how I can get this to work:
      public class CheckBoxRenderer extends CheckBox
              override public function set data(value:Object):void {
                  if(value){
                      super.data = value;
                      Server(super.data).addEventListener("setSelectionChanged", valueChange);
                      this.selected = value.selectedForDeployment;
              public function CheckBoxRenderer(){
                  focusEnabled = false;
                  BindingUtils.bindSetter(selectionChange, this, "selected");
              //this method occurs the checkbox is clicked
              public function selectionChange(value:Boolean):void{
                  trace(value);
                  this.selected = value;
                  if(this.data){
                      this.data.selectedForDeployment = value;
              //This method occurs when the selectedForDeployment boolean in the object changes
              public function valueChange(event:Event):void{
                  this.selected = event.target.selectedForDeployment;
              /* center the checkbox if we're in a datagrid */
              override protected function updateDisplayList(w:Number, h:Number):void
                  super.updateDisplayList(w, h);
                  if (listData is DataGridListData)
                      var n:int = numChildren;
                      for (var i:int = 0; i < n; i++)
                          var c:DisplayObject = getChildAt(i);
                          if (!(c is TextField))
                              c.x = (w - c.width) / 2;
                              c.y = (h - c.height) / 2;
        • 1. Re: CheckBox Item Renderer checks wrong grid row after sorting
          rtalton Level 4
          This usually works for me:
          package renderers
              import flash.events.Event;
              import mx.controls.CheckBox;
                      super();
                      addEventListener(Event.CHANGE, handleChange);
                      if(value){
                          super.data = value;
                  private function handleChange(event:Event):void{
                      data.selectedForDeployment = event.target.selected;
