9 Replies Latest reply on Oct 27, 2010 3:38 AM by TheGarfunkal
    Response from server into arraycollection trauma
    TheGarfunkal
      Hi.
      Hopefully someone can help - coz i am freaking out, and can't find a solution.
      I am developing an application that takes a variety of bits of info and displays them in pods within a page.
      One of the bits of info takes ONE row from a database table and tries (currently) to put it into a datagrid.
      Now, I know Flex wont allow that, so I have tried all kinds of things to fix it - using the xml directly, trying to get the info into labels casting as an array, using xmlistcollections... so much time on Google but now I am stuck.  I'm not precious about getting the info into a datagrid - in fact I'd rather put it into labels or text boxes so I can presents it in a more flexible way.
      Looking in the debugger, it seems like I don't even have the data in my variable - I do have it in the event so it is there, but I can't for the life of me get it out...
      This obviously works fine for multiple rows of data in the array - not the single row.  i'm trying to get the info into a var called _SystemStatus. I dont even know if that is the right way to go
      Please any suggestions?
      Overview of Code:
      I have a mxml but with all the presentation stuff in.  I also have two actionscript modules with code in (you may have  guessed that I am new to this, so I have found most of this great code on the internet)
      The AS bits are
      sql.as - this basically is a load of functions called by the mxml which contain the sql to send to the database
      mssql.as - this does all the magic of getting the data from the db, and taking it from the event.
      Current Debugger output:
      Code below:
      CompletionTimes.mxml (note - its got errors in where i have tried things)
      <PodContentBase
      xmlns="dashboard.view.ActionScript.*"
      xmlns:mx="http://www.adobe.com/2006/mxml"
      width="100%" height="100%">
      <mx:Script source="ActionScript/MSsql.as"/>
      <mx:Script source="ActionScript/sql.as"/>
      <mx:Text text="This is the trend overview. Maximise Pod to view details."/>
          <mx:TextArea text="{CMIPortal.ChosenSystem}"/>
      <mx:Label text="'gfgfg'+ '{_SystemStatus.getItemAt(0)}'" />
      <mx:DataGrid  id="dgSystemStatus" height="86" width="100%" creationComplete="{SystemStatus()}" dataProvider="{_SystemStatus}" themeColor="#E166B5" color="#3C3C3C" >
      <!-- <mx:columns>
      <mx:DataGridColumn dataField="Application" headerText="Application"   />
      <mx:DataGridColumn dataField="Available" headerText="Available"  width="65"  />
      <mx:DataGridColumn dataField="Last_Update" headerText="Last Update"  color="#3C3C3C"  />
      <mx:DataGridColumn dataField="Data_Current" headerText="Data Current"/>
      </mx:columns> -->
      </mx:DataGrid>
      </PodContentBase>
      sql.AS
      // ActionScript file
      import mx.events.ListEvent;
      import mx.controls.Alert;
      private function SystemStatus():void {
         mssqlQuery("SELECT * FROM [MI_Specialists].[dbo].[Portal_SystemStatus] WHERE [Application] =  '" +  CMIPortal.ChosenSystem   + "' AND  ID in ( SELECT MAX([Id]) [Application] FROM  [MI_Specialists].[dbo].[Portal_SystemStatus] group by [Application]) ","SystemStatus");
      msSql.As
      import mx.charts.*;
      import mx.collections.ArrayCollection;
      import mx.collections.XMLListCollection;
      import mx.rpc.AsyncToken;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.http.mxml.HTTPService;
      import mx.utils.ArrayUtil;
      private var sqlToken:AsyncToken;
      * Your Configuration Paramaters
      public var mssql_db:String = "MI_Specialists";
      * MS SQL Query Function
      public function mssqlQuery(sql:String,fid:String):void {
      var http:HTTPService = new HTTPService;
      var parm:Object = new Object;
      parm.fas_sql = sql;
      parm.fas_db = mssql_db;
      http.url = mssql_url+"?irand="+Math.random();
      http.showBusyCursor = true;
      http.request = sql;
      http.addEventListener(ResultEvent.RESULT, mssqlResult);
      http.addEventListener(FaultEvent.FAULT, mssqlFault);
      http.method = "POST";
      http.resultFormat="e4x"
      sqlToken = http.send(parm);
      sqlToken.param = fid;
      private function mssqlFault(event:FaultEvent):void {
      var err:String = event.fault.faultString;
      Alert.show(err);
      // fname.text = err
      [Bindable]
      private  var _SystemStatus:ArrayCollection = new ArrayCollection();
      private function mssqlResult(event:ResultEvent):void{
      //Note: All Results are stored in the
      // event.result object
      //Create a new case/break for each of your
      //sql query statements
      switch(event.token.param){
      case "SystemStatus":
      _SystemStatus = new ArrayCollection([event.result.results.record]);
      // _SystemStatus =  event.result.results.record;
      break;
      break;
      * Functions: Query Requests
      public function addslashes(tt:String):String{
      //replaces all occurrences
          var ttt:String = tt.replace(/\u0027+/g,"''");
      return ttt;
        • 1. Re: Response from server into arraycollection trauma
          Claudiu Ursica Level 4
          DO you get the data ater making the http call?
          C
          • 2. Re: Response from server into arraycollection trauma
            TheGarfunkal Level 1
            Hi Ursica
            I assume so, as the data is returned into the event.result.results.record - I can see it in the debugger.
            Maybe I need to think of a way to get the data from there into another control or collection. I've tried loads - no success.
            • 3. Re: Response from server into arraycollection trauma
              I see you have XML response. I rarely bind to XML, instead I use a custom
              unmarshaller to parse data into come custom typed class. You can build also a
              wrapper class over the Xml to expose data through bindable getters/setter.
              Whatever suits you better.
              However I think XMLListCollection it seems more appropriate from what I see
              you've posted.
              Here I think you have the issues. event.result.results probably returns an
              XMLList. check to see if it has valid results. If so wrap it inside a
              XMLListCollection. new XMLListCollection(xmlLIst).
              _SystemStatus = your new listCollection.
              P.S.
              Try it on your own since I don't have your code to compile so I write from my
              memory.
              HTH,
              C
              • 4. Re: Response from server into arraycollection trauma
                Hi - thanks again fro your help.
                I'm not sure how I check that the XMLlist returned valid results
                The event result says it is XML, and the Variables I've set up are shown in the debugger as:
                _135458828_SystemStatusColl mx.collections.XMLListCollection (@3209281)
                _1667321088_SystemStatus XMLList (@32463a1)
                So, I assume the _SystemStatus IS an XMLList -  However the debugger shows no data for it.
                Ive changed the code in msSql.as to have an extra variable:
                [Bindable]
                // private  var _SystemStatus:ArrayCollection = new ArrayCollection();
                private  var _SystemStatus:XMLList  = new XMLList();
                [Bindable]
                private  var _SystemStatusColl:XMLListCollection;
                and changed the case to say
                // _SystemStatus = new ArrayCollection([event.result.results.record]);
                _SystemStatusColl =  new XMLListCollection(_SystemStatus);
                break;
                Still no data in the grid!  Any suggestions?
                • 5. Re: Response from server into arraycollection trauma
                  Send me an sample XML and I;ll parse it for you I don't have time to create it
                  by hand from the image but you have the debugger so just do a copy paste.
                  C
                  • 6. Re: Response from server into arraycollection trauma
                    The data  copied from the record level of the event.result.results.records debugger is:
                    <record>
                      <Id>
                        <![CDATA[54]]>
                      </Id>
                      <Todays_Date>
                        <![CDATA[14/09/2010]]>
                      </Todays_Date>
                      <Application>
                        <![CDATA[AIS MI]]>
                      </Application>
                      <Status>
                        <![CDATA[Final]]>
                      </Status>
                      <Available>
                        <![CDATA[Yes]]>
                      </Available>
                      <Last_Update>
                      </Last_Update>
                      <Completion_Time>
                        <![CDATA[10.49]]>
                      </Completion_Time>
                      <Data_Current>
                        <![CDATA[13/09/2010]]>
                      </Data_Current>
                      <Comments>
                        <![CDATA[]]>
                      </Comments>
                    </record>
                    event mx.rpc.events.ResultEvent (@2f8eee1)
                    [inherited]
                    headers null
                    result XML
                    <results>
                    <record>
                    <Id>
                    <Todays_Date>
                    <Application>
                    <Status>
                    <Available>
                    <Last_Update>
                    <Completion_Time>
                    <Data_Current>
                    <Comments>
                    statusCode 200 [0xc8]
                    • 7. Re: Response from server into arraycollection trauma
                      I created a custom class it is more straight forward and you can debug...
                      package
                      public class Record
                      public var id:uint;
                      public var todaysDate:String; // put some date from string conversion here and
                      type as Date if necessary;
                      public var application:String;
                      public var status:String;
                      public var available:Boolean;
                      public var lastUpdate:String;
                      public var completionTime:Number;
                      public var dataCurrent:String;
                      public var comments:String;
                      public function toString():String
                      return "Record id = " + id +
                      " todaysDate = " + todaysDate +
                      " application = " + application +
                      " status = " + status +
                      " available = " + available +
                      " lastUpdate = " + lastUpdate +
                      " completionTime = " + completionTime +
                      " dataCurrent = " + dataCurrent +
                      " comments = " + comments;
                      hardcoded XML
                      private var resultXML:XML = ;
                      parsing code
                      var record:Record = new Record();
                      var result:XMLList = resultXML.record;
                      record.id = result.Id;
                      record.todaysDate = result.Todays_Date; // put some date from string conversion
                      here and type as Date if necessary;
                      record.application = result.Application;
                      record.status = result.Status;
                      record.available = result.Available;
                      record.lastUpdate = result.Last_Update; // put some date from string conversion
                      record.completionTime = result.Completion_Time;
                      record.dataCurrent = result.Data_Current; // put some date from string
                      conversion here and type as Date if necessary;
                      record.comments = result.Comments;
                      trace(record);
                      I don;t have time for the XML wrapper version now sorry. This should take u
                      forward. What you have to do is something like resultXML = event.result as XML;
                      instead of the hardocding part
                      C
                      • 8. Re: Response from server into arraycollection trauma
                        I was having a mess and found that i can reference the event.result directly....
                        [Bindable]
                        private  var _SSApplication:String = new String;
                        _SSApplication = event.result.*[0].*[2];
                        As i know there is only going to be one result that seems to suffice.  Phew!
                        Claudiu - thanks so much for your help - does my way look ok? I found it by messing in the debugger - using watch expressions.
                        • 9. Re: Response from server into arraycollection trauma
                          Check if the reference to the event is released after the assigned. If so you
                          are good to go ...
                          C
