0 Replies Latest reply on Oct 26, 2010 11:22 AM by Helioborges
    Help with Comboboxes inside a repeater
    Helioborges
      Hi, I have a problem that I really need some help, if anyone knows how to do it.
      I have to make in flex a dynamic form that has X questions and each question can be answered 3 times by sellecting Y options in a combobox. As you can Imagine the number of questions and answers can change.
      Something like this:
      QUESTION                          FIRST ANSWER   2nd ANSWER      3rd ANSWER
      1- Which option do you like?  Combobox: A      Combobox: C        CB: A
      2- Second Question?             Combobox: B      Combobox: C        CB: D
      3- Third Question?                 Combobox: A      Combobox: Blank  CB: B
      (CB: means Combobox - I just made it shorter so it could fit the window)
      I managed to correctly using a repeater show all the questions and each combobox has all the right options inside. All I want now is to get the data from those comboboxes.
      This is a Simplified code (I removed all the non-essencial stuff) so you can get an idea:
      <mx:Repeater id="rp">
      <mx:VBox label="{rp.currentItem.nome}"
      width="100%">
      <mx:Repeater id="qt"
      dataProvider="{rp.currentItem.tbdavaliacao_pergunta}">
      <mx:HBox width="100%"
      verticalAlign="middle"
      horizontalAlign="center">
      <!-- This is the question text -->
      <mx:Text text="{String(qt.currentItem.nome)}"
      textAlign="center"/>
      <!-- Next, are the 3 comboboxes that are repeated X times -->
                                              <mx:ComboBox dataProvider="{grau}"
                                                             id="auto"
                                                             textAlign="center">
                                               </mx:ComboBox>
                                                             id="superior"
                                                             textAlign="center">
                                              </mx:ComboBox>
                                                             id="resultado"
                                                             textAlign="center">
                                              </mx:ComboBox>
      </mx:HBox>
      </mx:Repeater>
      </mx:VBox>
      </mx:Repeater>
      Anyone has an idea of how can I get all the answers from all my dynamic comboboxes?
      The perfect AND ideal solution would be having X Dynamic objects with the question id + the combobox id storing the answer sellected.
      So I would know that the question 32 has the answers A, B and A for an example.
      qt.currentitem.id + combobox.id = selectedLabel
      (question ID) + (combobox id) = (selectedLabel)
      32auto = 'A'
      32superior = 'B'
      32resultado = 'A'
      Or just one arraycollection with all the answers...
      At this point, I would accept any answer or idea or sollution...
      Thanks a lot!!
