1. Re: Clone Stamp Tool does not work
Silkrooster Oct 26, 2010 8:59 PM (in response to Jack)If you are working on multilayers, make sure sample all layers is enabled if working on a layer above the image.
2. Re: Clone Stamp Tool does not work
John Joslin Oct 27, 2010 12:38 AM (in response to Jack)Try resetting the tool from the drop-down menu next to the tool icon in the Options bar.
If that doesn't help, try resetting your PS preferences as described in the FAQ.
http://forums.adobe.com/thread/375776?tstart=0
You either have to physically delete (or rename) the preference files or, if using the Alt, Ctrl, and Shift method, be sure that you get a confirmation dialog.
This resets all settings in Photoshop to factory defaults.
A complete uninstall/re-install will not affect the preferences and a corrupt file there may be causing the problem.
3. Re: Clone Stamp Tool does not work
Jack Oct 27, 2010 7:17 AM (in response to Silkrooster)Thanks, but the problem persists even after flattening the image. "Sample all layers" appears to be set by default.
Best,
jwc
4. Re: Clone Stamp Tool does not work
Userbak610 Oct 27, 2010 7:22 AM (in response to Jack)Is the opacity set to zero?
5. Re: Clone Stamp Tool does not work
Jack Oct 27, 2010 7:24 AM (in response to John Joslin)The second method worked. Many thanks.
To avoid this happening again, would appreciate any idea on what to look for in my Preferences.
Best,
jwc
6. Re: Clone Stamp Tool does not work
Glad it fixed it.
When the preferences get corrupted it is not due to a wrong setting. One of the files has been damagrd. This is a known problem with computers not just Photoshop.
It can be caused by incorrect shut-downs, hard drive faults, or a dozen other reasons. Deleting the preferences just lets Photoshop generate a fresh set at factory default.
Make sure you check through to get your personal settings back and then save a copy.
7. Re: Clone Stamp Tool does not work
Jack Oct 27, 2010 2:12 PM (in response to John Joslin)Problem has returned on second attempt to use clone stamp tool. Tried reopening with Ctrl+Alt+shift depressed, got the "delete preferences file" dialog. Still unable to use clone stamp tool on flat file or background layer of layered image.
Further ideas appreciated.
8. Re: Clone Stamp Tool does not work - CS4 Win XP SP-3
Jack Oct 30, 2010 3:05 PM (in response to Jack)I am now finding that the reset of "preferences" file at startup of PS works consistently.
Bad news is that a stop/start with reset key combination is required after every instance of using my clone stamp tool.
Any ideas of what can be the cause, and a possible cure, would be appreciated.
9. Re: Clone Stamp Tool does not work - CS4 Win XP SP-3
dec9 Oct 30, 2010 3:34 PM (in response to Jack)Jack,
I would try these simple to do checks on your computer to help rule out problems.
Go to start and type in CMD. Your will see CMD.exe. Right click on that and choose run as Admin. Type in scf /scannow at the command prompt. This will check windows 7 system files and if problems are found will fix them. It may ask you for the disk or to reboot. Keep doing this until nothing is found. If nothing is found then everything is ok.
You should also scan the hard drive for disk errors. Something might be on a bad sector or trying to write to a bad sector.
http://windows.microsoft.com/en-US/windows7/Check-a-drive-for-errors
10. Re: Clone Stamp Tool does not work - CS4 Win XP SP-3
Jack Oct 30, 2010 4:51 PM (in response to dec9)Thanks dec but I'm running in XP. Will see what I can get done anyway. Thanks for tips.
