2 Replies Latest reply on Oct 26, 2010 7:40 PM by juz.newbie
    Preload Issue
    juz.newbie
      hey guys
      I'm having issue preloading embedded SWF file. For the first run, my SWF actually preloaded perfectly. But from the second run onwards, it does not show the animation, a dove flapping it wings, of the SWF instead it just kind of freeze there. It goes to the main after preload though.
      Code:
      package
          import flash.display.*;
          import flash.events.*;
          import flash.net.*;
          import flash.utils.*;
          import mx.events.*;
          import mx.preloaders.*;
          public class CustomPreloader extends Sprite
              implements IPreloaderDisplay
              [ Embed(source="../Graphics/mySWF.swf", mimeType="application/octet-stream") ]
              private var myLogo:Class;
              public var timer:Timer;
              private var logoLoader:flash.display.Loader;
              public function CustomPreloader() {
                  super();
              // Specify the event listeners.
              public function set preloader(preloader:Sprite):void {
                  preloader.addEventListener(
                      FlexEvent.INIT_PROGRESS, handleInitProgress);
                      FlexEvent.INIT_COMPLETE, handleInitComplete);
              public function initialize():void {
                  logoLoader = new flash.display.Loader();
                  logoLoader.contentLoaderInfo.addEventListener(
                      Event.COMPLETE, logoLoaderComplete);
                  logoLoader.visible = false;
                  logoLoader.loadBytes( new myLogo() as ByteArray );
                  addChild(logoLoader);
              // After the swf is loaded then display it.
              private function logoLoaderComplete(event:Event):void
                  logoLoader.stage.addChild(this)
                  logoLoader.x = logoLoader.stage.stageWidth/2 - logoLoader.width/2
                  logoLoader.y = logoLoader.stage.stageHeight/2 - logoLoader.height/2
                    logoLoader.visible=true;
              private function handleInitProgress(event:Event):void {
              //Application has downloaded so start the fade out.
              private function handleInitComplete(event:Event):void {
                  var timer:Timer = new Timer(2000,1);
                  timer.addEventListener(TimerEvent.TIMER, dispatchComplete);
                  timer.start();
                  closeScreen();
              private function dispatchComplete(event:TimerEvent):void {
                  dispatchEvent(new Event(Event.COMPLETE));
              public function closeScreen():void
                  timer = new Timer( 1 );
                     timer.addEventListener( TimerEvent.TIMER, closeScreenFade );
                  timer.start();
              public function closeScreenFade( event:TimerEvent ):void
                  if( logoLoader.alpha > 0){
                      logoLoader.alpha = logoLoader.alpha - .002;
                      this.alpha = this.alpha - .002;
                  } else {
                      timer.stop()
                      this.removeChild(logoLoader);
              public function get backgroundColor():uint {
                  return 0;
              public function set backgroundColor(value:uint):void {
              public function get backgroundAlpha():Number {
                  return 0;
              public function set backgroundAlpha(value:Number):void {
              public function get backgroundImage():Object {
                  return null;
              public function set backgroundImage(value:Object):void {
              public function get backgroundSize():String {
                  return "";
              public function set backgroundSize(value:String):void {
              public function get stageWidth():Number {
                  return 0;
              public function set stageWidth(value:Number):void {
              public function get stageHeight():Number {
                  return 0;
              public function set stageHeight(value:Number):void {
      Can anyone help me on this?
      Thanks in advance
