Now maybe I am doing it wrong but with CFNavigate, it has the
parameter for a "container" to refresh. What if I want the whole
page to refresh with the form fields passed into it? Based on the
CFML Reference Guide (pg 127) all I have to do is... "If you omit
this argument, the link is treated as a normal URL and the entire
page is refreshed."
So here's the basic thing I am trying to do... use
CFLAYOUTAREA which has a form in it and I have a link which should
pass the form variables from myform to the test_submit.cfm page.
Here's the basic code I am using:
<a
href="javascript:ColdFusion.navigate('test_submit.cfm',,'','','post','myform');">Submit
it</a>
If I leave the container field out of it... (no quotes), I
get: Syntax Error.
If I enter a '' (no space), I get: Error replacing HTML,
element not found.
If I enter a ' ' (with a space), I get the same error as
above: Error replacing HTML, element not found.
Am I using it wrong? is there a _root or something I need to
put in the container field for it to work?
Thanks.
Andy
