1 Reply Latest reply on Oct 28, 2010 12:30 PM by Fernando Geraldo Mantoan
    Hudson Integration
    Fernando Geraldo Mantoan Level 1
      Hi guys. I'm having trouble when integrating FlexPMD with Hudson. I'm using Maven for the build, and my pom.xml is as follows:
      <build>
                <sourceDirectory>src/main/flex</sourceDirectory>
                <testSourceDirectory>src/test/flex</testSourceDirectory>
                <plugins>
                     <plugin>
                          <groupId>org.sonatype.flexmojos</groupId>
                          <artifactId>flexmojos-maven-plugin</artifactId>
                          <version>${flexmojos-maven-plugin.version}</version>
                          <extensions>true</extensions>
                          <dependencies>
                               <dependency>
                                    <groupId>com.adobe.flex</groupId>
                                    <artifactId>compiler</artifactId>
                                    <version>${flexsdk.version}</version>
                                    <type>pom</type>
                               </dependency>
                          </dependencies>
                          <configuration>
                               <includeSources>
                                    <sources>${basedir}/src/main/flex</sources>
                               </includeSources>
                               <namespaces>
                                    <namespace>
                                         <uri>http://timeet.apolloti.com/</uri>
                                         <manifest>${basedir}/src/main/flex/manifest.xml</manifest>
                                    </namespace>
                               </namespaces>
                               <includeNamespaces>
                                    <namespace>http://timeet.apolloti.com/</namespace>
                               </includeNamespaces>
                               <includeFiles>
                               </includeFiles>
                          </configuration>
                     </plugin>
                     <!-- Flex PMD -->
                     <plugin>
                          <groupId>com.adobe.ac</groupId>
                          <artifactId>flex-pmd-maven-plugin</artifactId>
                          <version>${flexpmd.version}</version>
                          <executions>
                               <execution>
                                    <phase>package</phase>
                                    <goals>
                                         <goal>pmd</goal>
                                    </goals>
                               </execution>
                          </executions>
                          <configuration>
                               <failOnError>false</failOnError>
                          </configuration>
                     </plugin>
                     <!-- Flex PMD CPD -->
                     <plugin>
                          <artifactId>flex-pmd-cpd-maven-plugin</artifactId>
                          <executions>
                               <execution>
                                    <goals>
                                         <goal>check</goal>
                                    </goals>
                               </execution>
                          </executions>
                          <configuration>
                               <minimumTokenCount>5</minimumTokenCount>
                          </configuration>
                     </plugin>
                     <!-- Flex PMD Metrics -->
                     <plugin>
                          <artifactId>flex-pmd-metrics-maven-plugin</artifactId>
                          <executions>
                               <execution>
                                    <goals>
                                         <goal>check</goal>
                                    </goals>
                               </execution>
                          </executions>
                     </plugin>
                </plugins>
           </build>
      </project>
      I have Java and Flex projects in the job, the Java project generates the PMD warnings section in Hudson correctly, but the FlexPMD isn't showing. Seeing the console, the PMD of Hudson isn't parsing the Flex generated PMD.xml.
      Any suggestions?
      Regards.
