2 Replies Latest reply on Oct 29, 2010 11:51 AM by DARTHCYL0N
    AIR Application Sandbox Bridge Issue
    DARTHCYL0N
      I am having an issue accessing the sandbox bridge from my application core page.
      The only thing I think it might be is I am using ajax for a login procedure so it might bolo it because of that.
      if anyone has any ideas I could use a fresh pair of eyes,
      If I strip it and create a new basic client I can get the sandbox bridge to work and launch the internet explorer , but with this client it won't
      here is the code for my AIR app document
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
      <title>Viper: Nuclear Edition</title>
      <link rel="stylesheet" type="text/css" href="../../lib/css/viperapp-interface.css" />
      <link rel="stylesheet" type="text/css" href="../../lib/css/module-headers.css" />
      <link rel="stylesheet" type="text/css" href="../../lib/css/p7exp.css" />
              <script src="/AIRAliases.js"></script>
      <script type="text/javascript" src="../../lib/js/scripts.js"></script>
      <script type="text/javascript" src="../../lib/js/p7exp.js"></script>
              <script language="javascript">
      //This code is placed in the root document header
      //This function is written to run from the sandbox. It opens a url in an external browser
      function processURL(){
      var searchString = document.location.search;
      // strip off the leading '?'
      searchString = searchString.substring(1);
      var nvPairs = searchString.split("&");
      for (i = 0; i < nvPairs.length; i++)
      var nvPair = nvPairs[i].split("=");
      var name = nvPair[0];
      var value = nvPair[1];
      alert(searchString);
      function remoteLogin(){
      viperframe.location.href = 'http://devcenter.viperapp.com/cgi/login.cfm'+ searchString;
      function testRemote(){
      alert('this is working');
      function noLogin(){
      alert('Your login information was incorrect, please try again');
      top.location.href="login.html";
      function openExternalURL(href) {
      var request = new air.URLRequest(href);
      try {
      air.navigateToURL(request);
      catch (e) {
      alert(e);
      var Exposed = new Object();
      // expose the trace() function.
                   Exposed.trace = function(str) {
                      air.trace(str);
      Exposed.openExternalURL = openExternalURL;
      Exposed.testRemote = testRemote;
      Exposed.noLogin = noLogin;
      function doLoad() {
      //Place the Exposed object on the parentSandboxBridge property of the ui frame's window object.
      var frame =  document.getElementById('viperframe').contentWindow.parentSandboxBridge = Exposed;
      setIframeHeight('viperframe');
      remoteLogin();
      // window.callMe = document.getElementById('viperFrame').contentWindow.childSandboxBridge.callMe;
      //var frame = document.getElementById('viperFrame').contentWindow.parentSandboxBridge = Exposed;
      </script>
      </head>
      <body onload="doLoad();" onresize="setIframeHeight('viperframe');" onfocus="setIframeHeight('viperframe');" bgcolor="#222222">
      <!-- END P7EXP PULLDOWN MENU -->
      <div id="headerToolBar">
      <div id="headerToolUser">
      <ul>
      <li><a href="javascript:void(0);">Logged in  <strong>
                          </strong></a></li>
      <li><a href="login.html" target="_parent"><strong>Log Out</strong></a></li>
      <li><div id="windowTools"><a href="javascript:void(0);" onClick="parent.minimizeWindow()"><img src="../../lib/img/headertoolbar/icon_minimizewindow.png" width="18" height="18" border="0" /></a><a href="javascript:void(0);" onClick="parent.maximizeWindow()"><img src="../../lib/img/headertoolbar/icon_expandwindow.png" width="18" height="18" border="0" /></a><a href="javascript:void(0);" onClick="parent.closeWindow()"><img src="../../lib/img/headertoolbar/icon_closewindow.png" width="18" height="18" border="0" /></a><div class="clearfloat"></div></div></li>
      </ul>
      </div>
      <div id="menuwrapper">
      <ul id="p7menubar">
      <!-- ADD SIDEBAR - TO COME IN LATER
      <li class="topnav"><a href="javascript:void(0);" class="trigger2"><img src="../../lib/img/headertoolbar/toolbar_icon_sidebar_open.png" width="27" height="13" border="0" /></a></li>
        <!-- PLANT SELECTOR - NOT FOR DELIVERABLE
      <li class="topnav"><a href="javascript:void(0);" class="trigger">Plant: <strong>SNPP</strong></a>
      <ul>
      <li><a href="javascript:void(0);">Plant Selector</a></li>
      <li><em> </em></li>
      <li><a href="javascript:void(0);">SNPP</a></li>
      <li><a href="javascript:void(0);">BM</a></li>
      <li><a href="javascript:void(0);">SRNP</a></li>
      </ul>
      </li>
      <li class="topnav"><a href="javascript:void(0);" class="trigger">File</a>
      <ul>
      <li><a href="login.html" target="_blank">New Window</a></li>
      <li><em> </em></li>
      <li><a href="javascript:window.print();" onclick="window.print();">Print</a></li>
      <li><em> </em></li>
      <li><a href="login.html" target="_parent">Log Out</a></li>
      <li><a href="javascript:void(0);" onClick="parent.closeWindow();">Quit VIPER</a></li>
      </ul>
      </li>
        <li class="topnav"><a href="http://designsupport.viperapp.com" target="_blank" class="trigger">Help</a>
        <ul>
      <li><a href="login.html" target="_parent">Reset Connection</a></li>
      <li><em> </em></li>
      <li><a href="http://designsupport.viperapp.com/contact.cfm" target="_blank">Contact Support</a></li>
                                  <li><a href="license.html" target="viperframe">View License</a></li>
      </ul>
      </li>
      </ul>
      </div>
      </div>
      <iframe src="" id="viperframe" name="viperframe" frameborder="0" scrolling="no" width="100%"></iframe>
      <!--<iframe name="viperFrame" id="viperFrame" src="http://devcenter.viperapp.com/VS/ui/screens/plantselections.html" frameborder="0" scrolling="no" width="100%"></iframe>-->
      </body>
      </html>
        • 1. Re: AIR Application Sandbox Bridge Issue
          DARTHCYL0N Level 1
          I have been mucking around with it and here is something interesting , if I throw the login the first time and then go in , it runs the ExternalURL command fine
          and if I login with the correct login without throwing it , it doesnt work, the only change is that when I type in the wrong login it runs a sandboxbridge command that takes the user back to the login page
          if I allow that command to run first then it will run the externalURL fine , if I don't then it won't , how odd is that,
          • 2. Re: AIR Application Sandbox Bridge Issue
            DARTHCYL0N Level 1
            I have tried running another command and it still doesn't run the external URL function, just if it runs my no login command via the sandbox bridge,
            and it is a simple command
            here is the javascript it is running on the nologin.
            function noLogin(){
            if it runs that over the sandboxbridge it works , if it doesnt then it doesnt.
            Anyone have any ideas, and I missing something on my iframe  ?
