3 Replies Latest reply on Oct 28, 2010 11:58 AM by Flex harUI
    Binding issue in Flex4, working example from Flex3
    travr
      The following example works in Flex3 but importing into the Flex4 there appears to an issue with binding. When the button is pressed the "userEvent" dispatched to Components.instance should cause the binding for "user" to update in the TextInput.
      This works in Flex 3 but not in Flex 4. I've tried compiling with Flex 3 compatibility mode to no avail. I have also tried creating a new Flex4 project with same functionality.
      Any idea why this should not work in Flex4?
      Application MXML
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" xmlns:local="*">
              // initialize service
           <local:ASComponents />
           <mx:Script><![CDATA[
                protected function handleClick():void
                     Components.instance.user = "test";
                     Components.instance.dispatchEvent( new Event( "userEvent" ) );
           ]]></mx:Script>
           <mx:Label text="User:" />
           <mx:TextInput text="{Components.instance.user}" editable="false" />
           <mx:Button label="Update User" click="handleClick()" />
      </mx:Application>
      ASComponents MXML
      <Components xmlns="*" xmlns:mx="http://www.adobe.com/2006/mxml">
      </Components>
      Components ActionScript Class
      package
           import flash.events.Event;
           import flash.events.EventDispatcher;
           import flash.events.IEventDispatcher;
           import mx.core.IMXMLObject;
           import mx.events.FlexEvent;
           public class Components extends EventDispatcher implements IMXMLObject
                /** Reference to singleton instance of this class. */
                private static var _instance:Components;
                private var _user:String = "";
                public function Components(target:IEventDispatcher=null)
                     super(target);
                     _instance = this;
                     dispatchEvent(new Event("instanceChanged"));
                public function initialized(document:Object, id:String):void
                     this.dispatchEvent( new FlexEvent("creationComplete",true));
                [Bindable(event="instanceChanged")]
                public static function get instance():Components
                     return _instance;
                [Bindable(event="userEvent")]
                public function get user():String
                     return this._user;
                public function set user( val:String ):void
                     this._user = val;
