3 Replies Latest reply on Oct 28, 2010 3:51 PM by Zabeth69-YATPtk
    Expand box on button click
    jattgolfer Level 1
      I'm not too sure what its called or what it is referred as, but how would I set up a box with a button that says "more" and when somebody clicks it, the box expands to show more information.
      Such as the one here:
      http://www.yelp.com/biz/mandarin-gourmet-palo-alto
      It's at the top titled "Special Lunch Box."
        • 1. Re: Expand box on button click
          Zabeth69-YATPtk Level 4
          What you see looks like a "disclosure widget," in this case a collapsible panel that has a "control" below the panel (typical simple collapsible panel controls are the panel 'bar'. By carefully aligning the borders, it looks like the box itself is expanding when you activate the widget.
          I have not located the css file that they used here, and it might actually be simpler than a disclosure widget...it might be all in the css.
          Here is the section of which you speak:
          <div id="bizAnnouncement">
                         <div id="anncInner" class="clearfix">
                              <div class="announcement_type SPECIAL_OFFER ieSucks"><strong>Special Lunch Box Only $6.00</strong></div>
                              <p id="bizAnnounDesc">Served from 11:30 am to 2:15 pm, mon ~ fri<br>Tax Included &amp; Cash Only<br>Order More Than 10 Items Get Free Deliver&#8230;</p>
                                   <div id="bizAnnounDesc_more" class="pseudoLink">More &raquo;</div>
                                   <div id="bizAnnounDesc_less" class="pseudoLink" style="display: none;">&laquo; Hide</div>
                         </div>
                         <div id="anncBtm"> </div>
          I might be missing the closing </div> tag, but you get the idea.
          Okay, the rest of the 'hidden' announcement is in javascript (they still left the 'y' off delivery):
                                   new Yelp.biz_announce('bizAnnounDesc', "wYRuMXPm0eQCFAtqC77qtw", "Served from 11:30 am to 2:15 pm, mon ~ fri<br>Tax Included &amp; Cash Only<br>Order More Than 10 Items Get Free Deliver<br> *Gift certificate 10% OFF");
          Not sure which javascript file this comes from; perhaps someone with javascript chops can chime in...
          Beth
          • 2. Re: Expand box on button click
            calijatt4lyfe Level 1
            so could i use the collapsible panel, and put the tab on the bottom? or is there a better way to do it?
            • 3. Re: Expand box on button click
              Sure. My recommendation is that you play around with collapsible panels.
              Look most of the way down this page: http://labs.adobe.com/technologies/spry/samples/collapsiblepanel/collapsible_panel_sample. htm# and you will see links that open and close the panel.
              Keep in mind that you can do a great deal to style the panels and tabs; they don't even have to look like panels and tabs.
              Beth
