3 Replies Latest reply on Oct 28, 2010 3:28 AM by Claudiu Ursica
    Problem in File Uploading
    Resmi Adhal
      <mx:Panel xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:com="*"
           layout="vertical" width="100%" minWidth="400" height="100%" minHeight="200"
           title="Upload Files" creationComplete="initCom()">
           <mx:Metadata>
                [Event(name="uploadComplete", type="flash.events.Event")]
                [Event(name="uploadProgress", type="flash.events.ProgressEvent")]
                [Event(name="uploadCancel", type="flash.events.Event")]
                [Event(name="uploadIOError", type="flash.events.IOErrorEvent")]
                [Event(name="uploadSecurityError", type="flash.events.SecurityErrorEvent")]
           </mx:Metadata>
           <mx:Script>
                <![CDATA[
                     Written by:
                     Dustin Andrew
                     dustin@flash-dev.com
                     www.flash-dev.com
                     FileUpload
                     Panel component for uploading files.
                     (Icons from http://www.famfamfam.com)
                     LAST UPDATED:
                     12/15/06
                     import mx.controls.*;
                     import mx.managers.*;
                  import mx.events.*;
                     import flash.events.*;
                     import flash.net.*;
                     private var _strUploadUrl:String;
                     private var _refAddFiles:FileReferenceList;
                     private var _refUploadFile:FileReference;
                     private var _arrUploadFiles:Array;
                     private var _numCurrentUpload:Number = 0;
                     // Set uploadUrl
                     public function set uploadUrl(strUploadUrl:String):void {
                          _strUploadUrl = strUploadUrl;
                     // Initalize
                     private function initCom():void {
                          _arrUploadFiles = new Array();
                          enableUI();
                          uploadCheck();
                     // Called to add file(s) for upload
                     private function addFiles():void {
                          _refAddFiles = new FileReferenceList();
                          _refAddFiles.addEventListener(Event.SELECT, onSelectFile);
                          _refAddFiles.browse();
                     // Called when a file is selected
                     private function onSelectFile(event:Event):void {
                          var arrFoundList:Array = new Array();
                          // Get list of files from fileList, make list of files already on upload list
                          for (var i:Number = 0; i < _arrUploadFiles.length; i++) {
                               for (var j:Number = 0; j < _refAddFiles.fileList.length; j++) {
                                    if (_arrUploadFiles[i].name == _refAddFiles.fileList[j].name) {
                                         arrFoundList.push(_refAddFiles.fileList[j].name);
                                         _refAddFiles.fileList.splice(j, 1);
                                         j--;
                          if (_refAddFiles.fileList.length >= 1) {
                               for (var k:Number = 0; k < _refAddFiles.fileList.length; k++) {
                                    _arrUploadFiles.push({
                                         file:_refAddFiles.fileList[k]});
                               listFiles.dataProvider = _arrUploadFiles;
                               listFiles.selectedIndex = _arrUploadFiles.length - 1;
                          if (arrFoundList.length >= 1) {
                               Alert.show("The file(s): \n\n• " + arrFoundList.join("\n• ") + "\n\n...are already on the upload list. Please change the filename(s) or pick a different file.", "File(s) already on list");
                          updateProgBar();
                          scrollFiles();
                          uploadCheck();
                     // Called to format number to file size
                     private function formatFileSize(numSize:Number):String {
                          var strReturn:String;
                          numSize = Number(numSize / 1000);
                          strReturn = String(numSize.toFixed(1) + " KB");
                          if (numSize > 1000) {
                               numSize = numSize / 1000;
                               strReturn = String(numSize.toFixed(1) + " MB");
                                    strReturn = String(numSize.toFixed(1) + " GB");
                          return strReturn;
                     // Called to remove selected file(s) for upload
                     private function removeFiles():void {
                          var arrSelected:Array = listFiles.selectedIndices;
                          if (arrSelected.length >= 1) {
                               for (var i:Number = 0; i < arrSelected.length; i++) {
                                    _arrUploadFiles[Number(arrSelected[i])] = null;
                               for (var j:Number = 0; j < _arrUploadFiles.length; j++) {
                                    if (_arrUploadFiles[j] == null) {
                                         _arrUploadFiles.splice(j, 1);
                                         j--;
                               listFiles.selectedIndex = 0;
                          updateProgBar();
                          scrollFiles();
                          uploadCheck();
                     // Called to check if there is at least one file to upload
                     private function uploadCheck():void {
                          if (_arrUploadFiles.length == 0) {
                               btnUpload.enabled = false;
                               listFiles.verticalScrollPolicy = "off";
                          } else {
                               btnUpload.enabled = true;
                               listFiles.verticalScrollPolicy = "on";
                     // Disable UI control
                     private function disableUI():void {
                          btnAdd.enabled = false;
                          btnRemove.enabled = false;
                          btnCancel.enabled = true;
                          listFiles.enabled = false;
                     // Enable UI control
                     private function enableUI():void {
                          btnAdd.enabled = true;
                          btnRemove.enabled = true;
                          btnCancel.enabled = false;
                          listFiles.enabled = true;
                     // Scroll listFiles to selected row
                     private function scrollFiles():void {
                          listFiles.verticalScrollPosition = listFiles.selectedIndex;
                          listFiles.validateNow();
                     // Called to upload file based on current upload number
                     private function startUpload():void {
                          if (_arrUploadFiles.length > 0) {
                               disableUI();
                               listFiles.selectedIndex = _numCurrentUpload;
                               scrollFiles();
                               // Variables to send along with upload
                               var sendVars:URLVariables = new URLVariables();
                               sendVars.action = "upload";
                               var request:URLRequest = new URLRequest();
                               request.data = sendVars;
                              request.url = _strUploadUrl;
                              request.method = URLRequestMethod.POST;
                              _refUploadFile = new FileReference();
                              _refUploadFile = listFiles.selectedItem.file;
                              _refUploadFile.addEventListener(ProgressEvent.PROGRESS, onUploadProgress);
                                  _refUploadFile.addEventListener(Event.COMPLETE, onUploadComplete);
                              _refUploadFile.addEventListener(IOErrorEvent.IO_ERROR, onUploadIoError);
                                 _refUploadFile.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onUploadSecurityError);
                              _refUploadFile.upload(request, "file", false);
                     // Cancel and clear eventlisteners on last upload
                     private function clearUpload():void {
                          _refUploadFile.removeEventListener(ProgressEvent.PROGRESS, onUploadProgress);
                          _refUploadFile.removeEventListener(Event.COMPLETE, onUploadComplete);
                          _refUploadFile.removeEventListener(IOErrorEvent.IO_ERROR, onUploadIoError);
                          _refUploadFile.removeEventListener(SecurityErrorEvent.SECURITY_ERROR, onUploadSecurityError);
                          _refUploadFile.cancel();
                          _numCurrentUpload = 0;
                          updateProgBar();
                          enableUI();
                     // Called on upload cancel
                     private function onUploadCanceled():void {
                          clearUpload();
                          dispatchEvent(new Event("uploadCancel"));
                     // Get upload progress
                     private function onUploadProgress(event:ProgressEvent):void {
                          var numPerc:Number = Math.round((event.bytesLoaded / event.bytesTotal) * 100);
                          updateProgBar(numPerc);
                          var evt:ProgressEvent = new ProgressEvent("uploadProgress", false, false, event.bytesLoaded, event.bytesTotal);
                          dispatchEvent(evt);
                     // Update progBar
                     private function updateProgBar(numPerc:Number = 0):void {
                          var strLabel:String = (_numCurrentUpload + 1) + "/" + _arrUploadFiles.length;
                          strLabel = (_numCurrentUpload + 1 <= _arrUploadFiles.length && numPerc > 0 && numPerc < 100) ? numPerc + "% - " + strLabel : strLabel;
                          strLabel = (_numCurrentUpload + 1 == _arrUploadFiles.length && numPerc == 100) ? "Upload Complete - " + strLabel : strLabel;
                          strLabel = (_arrUploadFiles.length == 0) ? "" : strLabel;
                          progBar.label = strLabel;
                          progBar.setProgress(numPerc, 100);
                          progBar.validateNow();
                     // Called on upload complete
                     private function onUploadComplete(event:Event):void {
                          _numCurrentUpload++;
                          if (_numCurrentUpload < _arrUploadFiles.length) {
                               startUpload();
                          } else {
                               enableUI();
                               clearUpload();
                               dispatchEvent(new Event("uploadComplete"));
                     // Called on upload io error
                     private function onUploadIoError(event:IOErrorEvent):void {
                          clearUpload();
                          var evt:IOErrorEvent = new IOErrorEvent("uploadIoError", false, false, event.text);
                          dispatchEvent(evt);
                     // Called on upload security error
                     private function onUploadSecurityError(event:SecurityErrorEvent):void {
                          clearUpload();
                          var evt:SecurityErrorEvent = new SecurityErrorEvent("uploadSecurityError", false, false, event.text);
                          dispatchEvent(evt);
                     // Change view state
                     private function changeView():void {
                          currentState = (currentState == "mini") ? "" : "mini";
           </mx:Script>
           <mx:states>
                <mx:State name="mini">
                     <mx:SetProperty name="height" value="60"/>
                     <mx:SetProperty name="minHeight" value="60"/>
                     <mx:SetStyle target="{btnView}" name="icon" value="@Embed('assets/application_put.png')"/>
                </mx:State>
           </mx:states>
           <mx:transitions>
                <mx:Transition fromState="*" toState="*">
                     <mx:Resize target="{this}" duration="1000"/>
                </mx:Transition>
           </mx:transitions>
           <mx:Canvas width="100%" height="100%">
                <mx:DataGrid id="listFiles" left="0" top="0" bottom="0" right="0"
                     allowMultipleSelection="true" verticalScrollPolicy="on"
                     draggableColumns="false" resizableColumns="false" sortableColumns="false">
                     <mx:columns>
                          <mx:DataGridColumn headerText="File" dataField="name" wordWrap="true"/>
                          <mx:DataGridColumn headerText="Size" dataField="size" width="75" textAlign="right"/>
                     </mx:columns>
                </mx:DataGrid>
           </mx:Canvas>
           <mx:ControlBar horizontalAlign="center" verticalAlign="middle">
                <mx:Button id="btnAdd" toolTip="Add file(s)" click="addFiles()" icon="@Embed('assets/add.png')" width="26"/>
                <mx:Button id="btnRemove" toolTip="Remove file(s)" click="removeFiles()" icon="@Embed('assets/delete.png')" width="26"/>
                <mx:ProgressBar id="progBar" mode="manual" label="" labelPlacement="center" width="100%"/>
                <mx:Button id="btnCancel" toolTip="Cancel upload" icon="@Embed('assets/cancel2.png')" width="26" click="onUploadCanceled()"/>
                <mx:Button label="Upload" toolTip="Upload file(s)" id="btnUpload" click="startUpload()" icon="@Embed('assets/bullet_go.png')"/>
                <mx:Button id="btnView" toolTip="Show/Hide file(s)" icon="@Embed('assets/application_get.png')" width="26" click="changeView()"/>
           </mx:ControlBar>
      </mx:Panel>
      Hi
      I have used this code for file uploading.But it is not working.The upload function is not working properly.The error thrown is
      TypeError: Error #2007: Parameter url must be non-null.
      Please help me.
      Regards
      Resmi
        • 1. Re: Problem in File Uploading
          Claudiu Ursica Level 4
          is your _strUploadUrl being set somewhere? I can see the setter but don't see
          the setter being called ...
          C
          • 2. Re: Problem in File Uploading
            Resmi Adhal Level 1
            Hi
            Thank you for your help.I set the url as suggested by you.
            The code is as follows:
                                disableUI();
                                scrollFiles();
                                                    set_uploadUrl("http://localhost:8080/ProjectName/NewFolder/");
            But below shown  error found.
            Unhandled uploadIoError:. text=Error #2038: File I/O Error. URL: http://localhost:8080/ProjectName/NewFolder/
            Please help me.
            Regards
            Resmi
            • 3. Re: Problem in File Uploading
              Due to my knowledge (try to look further yourself, since I have limited
              knowledge), there might be 3 reasons.
              1. URL is not valid (typos, wrong url the folder does not exist) - really doubt
              that is here
              2. Your directory does not have the write access (chmod 666 to give full acess
              look into chmod to see other possible values), probably not the case since you
              seem to be local.
              3. Your server side script yields an error. I assume that
              inside http://localhost:8080/ProjectName/NewFolder/ is an index.something that
              processes the bytes you send.
              C
