1 Reply Latest reply: Oct 28, 2010 9:13 AM by deerowbear RSS
    opening a document with a dialog open
    deerowbear Community Member
      I am trying to open a document with a window open created by javascript, but I get an error when the window is open and I try to open the document. See attached:
      Is there no way to have a window open and the application open a document at the same time?
      See code, do you see any errors:
      #target "InDesign-7.0"
      #strict on
      UserInteractionLevels.neverInteract;
      var dlg;
      Validate the input by the user
      function validate()
           if(dlg.iPanel.inputPath.text == "")
                  alert("Error, please define a directory to convert.");
                  return -1;
          if(dlg.oPanel.outputPath.text == "")
                  alert("Error, please define an output directory.");
                  return -1;
          return 0
      define user text file
      input to define file path
      function getInput()
          var input_folder = Folder.selectDialog( 'Select the directory where you wish to open the files: ', '' );
          if (input_folder != null)
              this.parent.inputPath.text = input_folder.toString();
              this.parent.inputPath.enabled = false;
      define user output path
      function getOutput()
      var output = Folder.selectDialog( 'Select the directory where you wish to output the files: ', '' );
      try
      this.parent.outputPath.text = output.toString();
      catch(e)
      alert("Path is undefined");
      this.parent.outputPath.enabled = false;
      return;
      function for writting out
      errors.
      function log_status(msg, file)
      if(errorFile.exists == true)
      alert("File  exist")
      errorFile.open("e", "", "")
      errorFile.write(msg + "\n");
      errorFile.close();
      else
      alert("File no exists");
      errorFile.open("w", "", "")
      errorFile.write(msg+ "\n") ;
      errorFile.close();
      return;
      open indesign file
      function openFile(file)
          try
          app.open(File(file));
          catch(e)
          alert(e);
      return;
      Export PDF
      function exportPDF(output)
      main function to convert
      indesign files to pdf
      function main()
          var errorFileObj = new File("c:/errorFile.txt");
          var successFileObj = new File("c:/successFile.txt");
          errorFileObj.open("w", "", "");
          successFileObj.open("w", "", "");
          if(validate() == -1)
              return;
          var input_folder = new Folder(dlg.iPanel.inputPath.text);
          files_array = input_folder.getFiles( '*.indd' );
          //dlg.close(1);
          for(var i = 0; i < files_array.length; i++)
              try
                  openFile(files_array[i]);
              catch(e)
                  errorFileObj.write(files_array[i]+ "\n") ;
                  continue;
              try
                  //exportPDF(output);
                  successFileObj.write(files_array[i]+ "\n") ;
              catch(e)
                  continue;
              alert(files_array[i]);
          successFileObj.close();
          errorFileObj.close();
          alert ("Files finished converting");
      create an instance of GUI for
      user input
      function createGUI()
      dlg = new Window('dialog', 'Indesign to PDF:', [100,100,480,300]);
      dlg.iPanel = dlg.add('panel',[5,10,375,80], 'Define Input');
      dlg.iPanel.inputText = dlg.iPanel.add('statictext', [10,12,125,25], 'Browse for directory:');
      dlg.iPanel.inputBtn = dlg.iPanel.add('button', [10,30,110,50], 'Browse');
      dlg.iPanel.inputPath = dlg.iPanel.add('edittext', [120,30,350,50], '');
      dlg.iPanel.inputBtn.onClick = getInput;
      dlg.oPanel = dlg.add('panel',[5,80,375,150], 'Define Output');
      dlg.oPanel.outputText = dlg.oPanel.add('statictext', [10,12,165,25], 'Browse for output directory:');
      dlg.oPanel.outputBtn = dlg.oPanel.add('button', [10,30,110,50], 'Browse');
      dlg.oPanel.outputPath = dlg.oPanel.add('edittext', [120,30,350,50], '');
      dlg.oPanel.outputBtn.onClick = getOutput;
      dlg.startBtn = dlg.add('button', [225,160,375,185], 'Start Conversion');
      dlg.startBtn.onClick = main;
      dlg.show();
      createGUI();//entry point for the script
        • 1. Re: opening a document with a dialog open
          Okay, this works....LAME....
          #strict on
          var dlg;
          var files_array;
          function validate()
                      return -1;
                      return -1;
              return 0
          function getInput()
          try
          catch(e)
          return;
          errors.
          alert("File  exist")
          errorFile.close();
          else
          errorFile.close();
          return;
          open indesign file
          function openFile(files_array)
                  try
                      app.open(File(files_array[i]));
                  catch(e)
                      alert(e);
                      continue;
          return;
          Export PDF
          function main()
                  return;
              dlg.close ();
              //dlg.destroy();
                  try
                  catch(e)
                      continue;
                  try
                  catch(e)
                      continue;
          user input
          dlg.show();
          openFile(files_array);
