7 Replies Latest reply on Oct 29, 2010 4:33 AM by deerowbear
    preflightProcess.saveReport not working in CS5?
    cweger79 Level 1
      Hi all,
      I'm trying to use the Scripting Guide demo script "ProcessPreflightProfile.jsx" to save a preflight report. It doesn't create a file at all. The relevant lines of code are:
      var myProcess = app.preflightProcesses.add(myDoc, myProfile);
      myProcess.waitForProcess();
      var myResults = myProcess.processResults;
      //If errors were found
      if (myResults != "None")
      //Export the file to PDF. The "true" value selects to open the file after export.
      myProcess.saveReport(File("~/Desktop/PreflightResults.pdf"), true);
      I'm using the demo script exactly as distributed, unmodified (except for the File path, which in the original script was "/C/blah blah").
      I know there are results, because myResults.length = 44, and I can see it in the debugger.
      Is there something amiss with saveReport? I've also tried setting the file extension to ".txt" which also does not generate a file.
      I'm hoping I'm just doing something stupid (the usual case) and someone will point me to the correct solution.
      Chuck
        • 1. Re: preflightProcess.saveReport not working in CS5?
          deerowbear
          Try taking out the ~ put the full path
          • 2. Re: preflightProcess.saveReport not working in CS5?
            deerowbear Level 1
            This function will allow you to save a pdf....it expects a document to be currently open and a parameter of type string for the ouput directory:
            Export PDF
            @param string output
            the path to save the pdf
            function exportPDF(output)
                with(app.pdfExportPreferences)
                    //Basic PDF output options.
                    pageRange = PageRange.allPages;
                    acrobatCompatibility = AcrobatCompatibility.acrobat6;
                    exportGuidesAndGrids = false;
                    exportLayers = false;
                    exportNonPrintingObjects = false;
                    exportReaderSpreads = false;
                    generateThumbnails = false;
                    try
                        ignoreSpreadOverrides = false;
                    catch(e)
                    includeBookmarks = true;
                    includeHyperlinks = true;
                    includeICCProfiles = true;
                    includeSlugWithPDF = false;
                    includeStructure = false;
                    interactiveElementsOption = InteractiveElementsOptions.doNotInclude;
                    //Setting subsetFontsBelow to zero disallows font subsetting;
                    //set subsetFontsBelow to some other value to use font subsetting.
                    subsetFontsBelow = 0;
                    //Bitmap compression/sampling/quality options.
                    colorBitmapCompression = BitmapCompression.zip;
                    colorBitmapQuality = CompressionQuality.eightBit;
                    colorBitmapSampling = Sampling.none;
                    //thresholdToCompressColor is not needed in this example.
                    //colorBitmapSamplingDPI is not needed when colorBitmapSampling
                    //is set to none.
                    grayscaleBitmapCompression = BitmapCompression.zip;
                    grayscaleBitmapQuality = CompressionQuality.eightBit;
                    grayscaleBitmapSampling = Sampling.none;
                    //thresholdToCompressGray is not needed in this example.
                    //grayscaleBitmapSamplingDPI is not needed when grayscaleBitmapSampling
                    //is set to none.
                    monochromeBitmapCompression = BitmapCompression.zip;
                    monochromeBitmapSampling = Sampling.none;
                    //thresholdToCompressMonochrome is not needed in this example.
                    //monochromeBitmapSamplingDPI is not needed when
                    //monochromeBitmapSampling is set to none.
                    //Other compression options.
                    compressionType = PDFCompressionType.compressNone;
                    compressTextAndLineArt = true;
                    cropImagesToFrames = true;
                    optimizePDF = true;
                    //Printers marks and prepress options.
                    //Get the bleed amounts from the document's bleed.
                    bleedBottom = app.activeDocument.documentPreferences.
                    documentBleedBottomOffset;
                    bleedTop = app.activeDocument.documentPreferences.documentBleedTopOffset;
                    bleedInside = app.activeDocument.documentPreferences.
                    documentBleedInsideOrLeftOffset;
                    bleedOutside = app.activeDocument.documentPreferences.
                    documentBleedOutsideOrRightOffset;
                    //If any bleed area is greater than zero, then export the bleed marks.
                    if(bleedBottom == 0 && bleedTop == 0 && bleedInside == 0 && bleedOutside == 0)
                        bleedMarks = true;
                    else
                    bleedMarks = false;
                    colorBars = true;
                    colorTileSize = 128;
                    grayTileSize = 128;
                    cropMarks = true;
                    omitBitmaps = false;
                    omitEPS = false;
                    omitPDF = false;
                    pageInformationMarks = true;
                    //pageMarksOffset = 12;
                    pdfColorSpace = PDFColorSpace.unchangedColorSpace;
                    //Default mark type.
                    pdfMarkType = 1147563124;
                    printerMarkWeight = PDFMarkWeight.p125pt;
                    registrationMarks = true;
                    try
                    simulateOverprint = false;
                    catch(e)
                    useDocumentBleedWithPDF = true;
                    //Set viewPDF to true to open the PDF in Acrobat or Adobe Reader.
                    viewPDF = false;
                //Now export the document. You'll have to fill in your own file path.
                var output_file = new File(output);
            var file = new File(output_file.fsName.toString() + "\\" + app.activeDocument.name.substring(0, app.activeDocument.name.lastIndexOf(".")) + ".pdf");
                app.activeDocument.exportFile(ExportFormat.pdfType, file,false);
            • 3. Re: preflightProcess.saveReport not working in CS5?
              cweger79 Level 1
              Thanks for your posts, but post #1 is incorrect and post #2 has nothing to do with my question.
              Re post #1: "A path name can start with a tilde (~) to indicate the user’s home directory. It corresponds to the platform’s HOME environment variable."
              -- JavaScript Tools Guide (CS5), page 41.
              I use tildes all the time in paths without a problem.
              Re post #2: I don't need to know how to export a PDF of the document; I want to save the preflight report, which according to the docs you can do by calling the method named "saveReport" on the preflightProcess object.
              Regards,
              Chuck
              • 4. Re: preflightProcess.saveReport not working in CS5?
                Larry G. Schneider Adobe Community Professional & MVP
                Do you have a Preflight profile called Test?
                • 5. Re: preflightProcess.saveReport not working in CS5?
                  cweger79 Level 1
                  Larry,
                  Good suggestion, but if I did not have a "Test" profile, the script would have failed at this line:
                  with the ever-popular "undefined is not an object" message.
                  Since it's not failing there, and since I DO have a "Test" profile, I'm afraid I can't award you points for the right answer. But, we have some lovely parting gifts AND a set of Samsonite luggage for you...
                  Regards,
                  Chuck
                  • 6. Re: preflightProcess.saveReport not working in CS5?
                    cweger79 Level 1
                    Additional information:
                    It turns out the the preflight report is actually implemented in ExtendScript, by a file named "ExportPreflightReport.jsx" inside the InDesign app's Scripts folder.
                    This script is apparently called by some C++ code inside InDesign. It's passed an array of arguments in the global "arguments" variable.
                    However, in my case, the "arguments" is zero-length; the C++ code is not supplying any arguments to the script.
                    Not sure what I can do about that at this point, but it was (for me) an interesting discovery.
                    • 7. Re: preflightProcess.saveReport not working in CS5?
                      deerowbear Level 1
                      This worked for me and made a pdf....I took the itemByName("Test"); out.
                      //ProcessPreflightProfile.jsx
                      //An InDesign CS5 JavaScript
                      //Shows how to process an InDesign preflight profile.
                      main();
                      function main(){
                      mySetup();
                      mySnippet();
                      myTeardown();
                      //<setup>
                      function mySetup(){
                      //</setup>
                      //<snippet>
                      function mySnippet(){
                      //<fragment>
                      // Assume there is a document.
                      var myDoc = app.documents.item(0);
                      // Assume the Test preflight profile exists.
                      var myProfile = app.preflightProfiles;
                      //Process the myDoc with the rule
                          try
                      catch(e)
                             alert(e);
                        myProcess.saveReport(File("/c/PreflightResults.pdf"), true);
                      //Cleanup
                      myProcess.remove();
                      //</fragment>
                      //</snippet>
                      //<teardown>
                      function myTeardown(){
                      //</teardown>
