• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Burrito code Hinting issue
Community Beginner ,
Oct 28, 2010 Oct 28, 2010
Hello there,
I've a big issue with code hinting on the brand new Burrito! For all class (native and created...) when i hit ctrl space i've nothing appear in th code hint panel!
Maybee somthing new must bee installed?
What a bug!
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Are you using an workspace from a prior installation? Make sure you start with a new workspace. The default one is "Adobe Flash Builder Burrito Preview" (C:\Users\Name\ one windows or ~/Documents/ on mac). If your project is using a specific SDK instead of the default one, remember to import the SDK under Preferences > Flash Builder > Installed SDKs.
Jason San Jose
Software Engineer, Flex Mobile
Votes
Translate
Translate
Report
Report
Engaged ,
I have the same problem on OS 10.6.4
The installation has all default parameters, yet Code assist works only in MXML, but not in CDATA
The preferences are OK:
Thanks for help,
FTQuest
Votes
Translate
Translate
Report
Report
The project where started first under Flash Builder 4 with air 2.5 SDK. But the project are mainly writted in pure AS3 (only the "main" class are in MXML). Frist, i've simply imported the project . Second, i've tryed to only import the pure AS3 class and rewritte my MXML whit a new burrito MXML, but completition still does'nt worked.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
If you overlayed the AIR SDK, then it's safe to assume that the original FB4 project was pointing to a specific SDK (per the AIR SDK overlay instructions).
Go to your project properties > Flex Compiler > Flex SDK version and choose "use default SDK".
FB Burrito already includes the AIR 2.5 SDK, so there is no more need to overlay.
Votes
Translate
Translate
Report
Report
New Here ,
I have the same issue but just in a flash professional project that was created in burrito.When in a pure AS project, code completion and/or hinting works fine. Talking about MAC OS x 10.5.8
Votes
Translate
Translate
Report
Report
New Here ,
Nov 02, 2010 Nov 02, 2010
i ran into this problem and the issue seems to be that by default now CTRL+SPACE is for code templates and not for code hinting.
It is frustrating that such a key shortcut has been changed by adobe. there has to be some different short cut now for code hinting and i can't find it. its not an SDK issue or anything.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
If you're seeing templates first instead of normal code hints, you might be experiencing a preferences bug. Go to Preferences > Flash Builder > Editors > ActionScript Code > Content Assist Cycling and press "Restore Defaults". Do the same for MXML Code. Let me know if that works.
Jason San Jose
Votes
Translate
Translate
Report
Report
Explorer ,
Nov 12, 2010 Nov 12, 2010
thanks, Jason!!!
I had this same issue that all of a sudden popped up. I followed your suggestion of restoring defaults and I was able to see code hinting as I had done a few days ago. I guess this is one of the joys of playing with a beta program. 😉
Votes
Translate
Translate
Report
Report
Explorer ,
Here's an update on my issue. I restore the defaults and after certain amount of time, the problem reoccurs and I once again have to restore the defaults. I'm not quite sure what I am doing (if anything) to cause the default behavior to change. Is this a bug with Burrito?
Votes
Translate
Translate
Report
Report
Guest
Nov 14, 2010 Nov 14, 2010
The bug has been resolved in latest builds of Burrito. https://bugs.adobe.com/jira/browse/FB-28451
Can you try creating a new workspace and see if it solves the issue? Import your existing projects in new workspace.
-Radhakrishna
Votes
Translate
Translate
Report
Report
New Here ,
Jan 21, 2011 Jan 21, 2011
LATEST
I've had this problem with all versions of FB. It will auto-complete and open-resource some of my packages/classes, but not all. Workaround is to run a script in BBEDIT that replaces spaces with tabs, then another does the reverse. This touches all my classes and refreshing FB does the trick. It's a bit of a pain. If anyone knows a better solution, I'd be happy to hear it.
-Gabriel
Can you get the rabbit back in the hat?
Houdini's Hat:
http://www.pizmogames.com/games/load.php?g=houdinishat
Votes
Translate
Translate
Report
Report
