2 Replies Latest reply on Oct 28, 2010 1:07 PM by mlavie
    How to Add an Asset to a Library
    mlavie Level 1
      I am trying to add an asset to a library in CS5, using the Library.store() method.
      I tried the following:
          var assetItemsArray:Array = new Array();
          assetItemsArray.push(page.allPageItems);
          var asset:Asset = library.store(assetItemsArray);
      but got this error message:
      Error: Invalid value for parameter 'using' of method 'store'. Expected Array of PageItems, Movies, Sounds, Graphics or XMLElements, but received ((TextFrame)).
      What am I doing wrong?
      TIA,
      mlavie
        • 1. Re: How to Add an Asset to a Library
          Harbs. Level 6
          You are feeding it an array of arrays...
          try:
          library.store(page.allPageItems);
          However that will give you nested items. You probably want this instead:
          library.store(page.pageItems.everyItem().getElements());
          Harbs
          • 2. Re: How to Add an Asset to a Library
            mlavie Level 1
            I see it's "Harbs to the rescue" again...
            Indeed, I had tried
            but it wouldn't compile in ActionScript, so I assumed that was not the way to go. Once you confirmed that that IS the solution, I tried
            library.store(page.allPageItems as Array);
            and that worked like a charm! And I DO need the nested items, thank you!
            mlavie
