3 Replies Latest reply on Dec 14, 2010 12:51 PM by richardl7
    Unload swf in Flash Pro
    Tonangel
      I publish a swf from a Catalyst Project and then load it in Flash Pro using the prebuild code snippet:
      myButton.addEventListener(MouseEvent.CLICK, fl_ClickToLoadUnloadSWF);
      var fl_Loader:Loader;
      function fl_ClickToLoadUnloadSWF(event:MouseEvent):void
      if(fl_ToLoad)
      fl_Loader = new Loader();
      fl_Loader.load(new URLRequest("Main.swf"));
      addChild(fl_Loader);
      else
      fl_Loader.unload();
      removeChild(fl_Loader);
      fl_Loader = null;
      fl_ToLoad = !fl_ToLoad;
      The swf is loaded but if i click the button again, the swf is not unloaded.
      I have used this code before with an swf created in flash and work fine but cant make it work with catalyst swf.
        • 1. Re: Unload swf in Flash Pro
          SrinivasAnnam Adobe Employee
             I hope that you declared "fl_ToLoad" variable outside the function. See the sample below:
                            var fl_ToLoad:Boolean=true;
            Once I declared this variable, the same code was working for me with Catalyst / Non-catalyst SWFs.
          Regards
          Srinivas Annam
          • 2. Re: Unload swf in Flash Pro
            Tonangel Level 1
            Thank you Srinivas, but i cant unload Catalyst swf. Thats my code now:
            if(fl_ToLoad)
            else
            fl_Loader.unload();
            fl_Loader = null;
            • 3. Re: Unload swf in Flash Pro
              richardl7
              Save the loader and use unloadAndStop(true);
                  var myContainer:Loader = new Loader();
                  var myURL:URLRequest=new URLRequest("game.swf")
                  myContainer.load(myURL);
                  addChild(myContainer);
              Later:
                  myContainer.unloadAndStop(true);
