0 Replies Latest reply on Oct 28, 2010 8:58 PM by thePlatypus
    Export ArrayCollection to XML
    thePlatypus
      I’m a little confused onhow to convert my ArrayCollection containing a custom class (actionscriptimport) in each node into an xml.
      My custom class is VERY simple…
      public class Widget
           public var name:String //typically I would make this private but I got no results without publicizing it
           public function Widget()
                 //constructor
           public function SetName(_name:String):void {
                name = _name;
            public function GetName():String {
                return name
      I create a bunch of these in an ArrayCollection using a simple form to feed in the data, then I want toexport the xml. I found the following code and tried to apply it…
      private function Convert_Click():void{
           arrayCollectionToXML(myAls);
      private functionarrayCollectionToXML(ac:ArrayCollection):void{
           varxml:XML
           for(var key:Object in myAls) {
                xml= objectToXML(myAls[key]);
                display.text+= xml;
      private functionobjectToXML(obj:Object):XML {
                               varqName:QName = new QName("root");
                                    varxmlDocument:XMLDocument = new XMLDocument();
                                    varsimpleXMLEncoder:SimpleXMLEncoder = new SimpleXMLEncoder(xmlDocument);
                                    varxmlNode:XMLNode = simpleXMLEncoder.encodeValue(obj, qName, xmlDocument);
                                    varxml:XML = new XML(xmlDocument.toString());
                                    returnxml;
      With my code as is when I input some widgets and assign names I get…
      <root><name>junk</name></root><root><name>junk1</name></root><root><name>junk2</name></roo t>
      I understand that each time I make a call to my function objectToXML() I am essentially stating to make another xml file, but I'm not sure how else to get xml output for my objects and their properties. When I directly pass theArrayCollection I get a breakdown on the object itself. I’ve seen where otherexamples usually piece their data together using arrays then converting them toan ArrayCollection.
      My question is… what am I missingto make this work the way I expect it? I’m tempted to simply iterate through myArrayCollection and concatenate a giant string.
