I have a datagrid which contains a Spark dropdownlist that needs to obtain dynamic data.
The datagrid uses a separate dataProvider.
When I use a static ArrayCollection within my ItemRenderer, it works (please see listing 1).
However, when I use Swiz to mediate a 'list complete' event to load the ArrayCollection, the dropdownlist does not show the new data (please see listing 2).
Using the debugger, I inspected the dropdownlist ItemRenderer and have confirmed the new data is being loaded into the ArrayCollection.
The new data is not shown in the UI control. I have tried invalidateProperties() + validateNow() and dispatching events on both the control and the renderer (this), but nothing seems to make the new data appear in the control on the datagrid.
Please help !!!
Listing 1: Datagrid and static ArrayCollection (this works)
<mx:DataGrid x="10" y="25" width="98%" id="dgInventory" paddingLeft="25" paddingRight="25" paddingTop="25" paddingBottom="25"
editable="true"
itemClick="dgInventory_itemClickHandler(event)" dataProvider="{acInventory}"
creationComplete="dgInventory_creationCompleteHandler(event)"
height="580">
<mx:columns>
<mx:DataGridColumn headerText="Item" dataField="itemName" itemRenderer="components.ItemRendererItem"
rendererIsEditor="true" editorDataField="selection" editable="true"/>
<mx:DataGridColumn headerText="Quantity Required" dataField="quantityReq" itemRenderer="components.ItemRendererQuantityRequired"
</mx:columns>
</mx:DataGrid><fx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import spark.events.IndexChangeEvent;
public var selection:int;
[Bindable]
protected var acItem:ArrayCollection = new ArrayCollection(
[ { itemName: "Item1"},
{ itemName: "Item2"},
{ itemName: "Item3"},
protected function dropdownlist1_changeHandler(e:IndexChangeEvent):void
selection = e.newIndex;
</fx:Script>
<s:DropDownList id="ddlItem" prompt="Select Item" dataProvider="{acItem}" labelField="itemName"
selectedIndex="{int(dataGridListData.label)}"
change="dropdownlist1_changeHandler(event)"
width="80%" top="5" bottom="5" left="5" right="5"/>
Listing 2: Dynamic ArrayCollection (does not work):
<s:MXDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx"
focusEnabled="true">
<fx:Script>
<![CDATA[
import event.ItemEvent;
import mx.events.FlexEvent;
[Bindable]
protected var acItem:ArrayCollection = new ArrayCollection();
protected function ddlItem_creationCompleteHandler(event:FlexEvent):void
var eve : ItemEvent = new ItemEvent( ItemEvent.LIST_ITEM_REQUESTED );
dispatchEvent( eve );
[Mediate( event="ItemEvent.LIST_ITEM_COMPLETE", properties="acItem" )]
public function refreshness( _acItem : ArrayCollection ):void
acItem.removeAll();
var len:int = _acItem.length;
if (len > 0)
for (var i:int=0; i < len; i++)
var newItem:Object = new Object;
newItem["itemName"] = _acItem.itemName;
acItem.addItem(newItem);
this.invalidateProperties();
this.validateNow();
//dispatchEvent(new FlexEvent(FlexEvent.DATA_CHANGE));
</fx:Script>
creationComplete="ddlItem_creationCompleteHandler(event)"
</s:MXDataGridItemRenderer>
After re-reading Peter Ent's ItemRenderer series, this turned out to be quite simple.
I extended DataGrid to have the ArrayCollection property I needed, then added this to my renderer:
[Bindable]
override public function set data( value:Object ) : void
super.data = value;
acItem = (listData.owner as MyDataGrid).itemList; // get the data from the renderer's container (by extending it to add a property, if necessary)
