0 Replies Latest reply on Oct 29, 2010 1:12 AM by mmiikkeemike
    remove frame problem?
    mmiikkeemike
      This script can't works in second file (if file name is 01xxx, 02xxx, 03xxx, if 01xxx infront of the windows, 03xxx can't work, if 02xxx infront of the windows 03xxx can't work) why?? please help
      Function here
      __________________________________
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
      var myDialog = app.dialogs.add({name:"Hide / Show / Deleted JOB BAR? ",canCancel:true});
      with(myDialog){
      with(dialogColumns.add()){
        with(borderPanels.add()){
        staticTexts.add({staticLabel:"JOB BAR (Please Choose)"});
        var myRadioButtonGroup = radiobuttonGroups.add();
        with(myRadioButtonGroup){
        var myHide = radiobuttonControls.add({staticLabel:"Hide"})
        var myShow = radiobuttonControls.add({staticLabel:"Show"})
        var myDeleted = radiobuttonControls.add({staticLabel:"Deleted"})
      for(a = 0; a < app.documents.length; a++){
      if (app.documents.item(a).colors.item ("JOB BAR") == null)
      app.documents.item(a).colors.add ({name:"JOB BAR", model:ColorModel.spot, colorValue:[100,100,0,0]});
      var myColor = app.documents.item(a).colors.item ("JOB BAR")
      var myRemoveColor = app.documents.item(a).colors.item("Job Bar");
      var replaceColor = app.documents.item(a).colors.item("JOB BAR");
      try{
      myRemoveColor.remove(replaceColor);
      catch(myRemoveColor){};
      try{
      var myLayer = app.documents.item(a).layers.item("JOB BAR LAYER");
      myLayer.visible=true;
      catch(myLayer){
      var myLayer = app.documents.item(a).layers.add({name: "JOB BAR LAYER", visible: true});
      myLayer.label = "JOB BAR LAYER";
      app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").locked=false;
      var myResult = myDialog.show();
      if(myResult == true){
      for(d = 0; d < app.documents.length; d++){
      if(((myDeleted.checkedState == true)&&myHide.checkedState == false)&&(myShow.checkedState == false)){
      var myActiveDoc = app.documents.item(d);
      app.activeDocument = myActiveDoc;
      app.findTextPreferences = NothingEnum.nothing;
      app.changeTextPreferences = NothingEnum.nothing;
      app.findTextPreferences.fillColor = myColor;
      app.findTextPreferences.findWhat = "♠ INTERNAL REF.";
      app.findChangeTextOptions.includeLockedLayersForFind = true;
      app.findChangeTextOptions.includeLockedStoriesForFind = true;
      app.findChangeTextOptions.wholeWord = true;
      app.findChangeTextOptions.includeMasterPages = true;
      var myFoundItems = app.documents.item(0).findText();
      for (j = 0; j < myFoundItems.length; j++) {
      var myFrame = myFoundItems[j].parentTextFrames;
      for (p = 0; p < myFrame.length; p++) {
      var mySelectedFrames = app.select(myFrame[p]);
      var mySelection = app.selection[p];
      mySelection.itemLayer.locked=false;
      myFrame[p].locked=false;
      myFrame[p].remove();}
      try{
      app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").remove();
      catch(e){
      else if((myHide.checkedState == true)&&(myShow.checkedState == false)&&(myDeleted.checkedState == false)){
      for (j = myFoundItems.length - 1; j >= 0; j--) {
      for (p = myFrame.length - 1; p >= 0; p--) {
      mySelection.itemLayer = "JOB BAR LAYER";}}
      app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").visible=false;
        app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").locked=true;
                  app.activeDocument.activeLayer = app.activeDocument.layers.item ("Layer 1");}
      else if((myHide.checkedState == false)&&(myShow.checkedState == true)&&(myDeleted.checkedState == false)){
      app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").visible=true;
        app.documents.itemByRange(0,-1).layers.item("JOB BAR LAYER").locked=false;}
      else{
      exit;
      ________________________________________
