0 Replies Latest reply on Oct 29, 2010 5:40 AM by VeyronSA
    docWindow.open(); Noob Help
    VeyronSA
      Hi All,
      New with the Flash Builder and have done some google`ing to check if someone had done this before, but i`m getting nowhere. So i would like some assistance with a error i have.
      I have created 2 mxml Appliction files, one is called "start" and the other "DocumentWindow". Using Flex 3.5 SDK.
      I want the "start" application to run as a pre-loader for the application set in "DocumentsWindow", the "start" application get the latest update from the server where hosted, after about 10 seconds then the application "start" should open the "DocumentsWindow" application. But I`m getting nowhere and i see that the following code is a problem but cant solve it:
      docWindow.open();
      Here us the full app for "start.mxml"
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
                                    layout="absolute"
                                    backgroundAlpha="0"
                                    horizontalScrollPolicy="off"
                                    verticalScrollPolicy="off"
                                    showFlexChrome="false"
                                    width="401"
                                    height="201"
                                    preinitialize="init()"
                                    creationComplete="checkUpdate()">
           <mx:Image id="backgroundImage"
                       source="images/sp_bg.png"
                       top="0"
                       left="0"
                       width="400"
                       height="200"
           <mx:Script>
                <![CDATA[
                     // Update Notice Function ////////////////////////////////////////////////
                     import air.update.ApplicationUpdaterUI;
                     import air.update.events.UpdateEvent;
                     import flash.events.ErrorEvent;
                     import mx.controls.Alert;
                     private var appUpdater:ApplicationUpdaterUI = new ApplicationUpdaterUI();
                     private function checkUpdate():void {
                          setApplicationVersion();
                          appUpdater.updateURL = "http://urltoserver/update.xml";
                          appUpdater.addEventListener(UpdateEvent.INITIALIZED, onUpdate);
                          appUpdater.addEventListener(ErrorEvent.ERROR, onError);
                          appUpdater.isCheckForUpdateVisible = false;
                          appUpdater.isFileUpdateVisible = false;
                          appUpdater.isInstallUpdateVisible = false;
                          appUpdater.initialize();
                     private function onUpdate(event:UpdateEvent):void {
                          appUpdater.checkNow();
                     private function onError(event:ErrorEvent):void {
                          Alert.show(event.toString());
                     private function setApplicationVersion():void {
                          var appXML:XML = NativeApplication.nativeApplication.applicationDescriptor;
                          var ns:Namespace = appXML.namespace();
                          lblAppVersion.text = "" + appXML.ns::version;
                     // Launch Main.mxml Function /////////////////////////////////////////////
                     import myComponents.DocumentWindow;
                     private const LOAD_DELAY:int = 4;
                     private var timeElapsed:int = 0;
                     private var loadTimer:Timer;
                     private var docWindow:DocumentWindow;
                     private function init():void
                          // center the window on the screen
                          var screenBounds:Rectangle = Screen.mainScreen.bounds;
                          nativeWindow.x = (screenBounds.width - nativeWindow.width) / 2;
                          nativeWindow.y = (screenBounds.height - nativeWindow.height) / 2;
                          // start the timer, which simulates a loading delay
                          loadTimer = new Timer(1000);
                          loadTimer.addEventListener(TimerEvent.TIMER, incrementTime);
                          loadTimer.start();
                          updateStatus();
                     private function incrementTime(event:TimerEvent):void
                          timeElapsed++;
                          updateStatus();
                          // if the loading delay has passed, stop the timer,
                          // close the splash screen, and open the document window
                          if ((LOAD_DELAY - timeElapsed) == 0)
                               loadTimer.stop();
                               loadTimer.removeEventListener(TimerEvent.TIMER, incrementTime);
                               loadTimer = null;
                               nativeWindow.close();
                               // open a new instance of the document window
                               docWindow = new DocumentWindow();
                               docWindow.open();
                     private function updateStatus():void
                          var timeRemaining:uint = LOAD_DELAY - timeElapsed;
                          var timeRemainingMsg:String = timeRemaining.toString() + " second";
                          if (timeRemaining != 1) { timeRemainingMsg += "s"; }
                          timeRemainingMsg += " remaining.";
           </mx:Script>
           <mx:VBox x="6" y="156">
           </mx:VBox>
           <mx:Label id="lblAppVersion" color="#CCCCCC" width="150" x="5" y="157"/>
           <mx:Label x="2" y="174"  color="#CCCCCC" text="Copyright © 2010 Company"/>
      </mx:WindowedApplication>
      Here is the full code for "DocumentsWindow"
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
                                    width="1000"
                                    height="660">
           <mx:Label x="389" y="39" text="Document Window" width="112" height="20"/>
      Can someone please tell me what to do
      Thanks!
      VeyronSA
