2 Replies Latest reply on Oct 29, 2010 11:56 AM by cortlander1
    Passing request data with Flashvars
    cortlander1
      I need to pass query parameters from one application to another and am following an example in help docs at
      http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf626ae-7feb.html
      So I am passing parameters through the wrapper object as below:
          String userId = (String) request.getParameter("userId");
          String authToken = (String) request.getParameter("authToken");
              <script type="text/javascript" src="swfobject.js"></script>
                  <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. -->
                  var swfVersionStr = "10.0.0";
                  <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. -->
                  var xiSwfUrlStr = "playerProductInstall.swf";
                  var flashvars = {};
                 flashvars.userId = "<%= userId %>";
                  flashvars.authToken = "<%= authToken %>";
                  var params = {};
                  params.quality = "high";
                  params.bgcolor = "#869ca7";
                  params.allowscriptaccess = "sameDomain";
                  params.allowfullscreen = "true";
                  var attributes = {};
                  attributes.id = "xacmlMain";
                  attributes.name = "xacmlMain";
                  attributes.align = "middle";
                  swfobject.embedSWF(
                      "main.swf", "flashContent",
                      "100%", "100%",
                      swfVersionStr, xiSwfUrlStr,
                      flashvars, params, attributes);
                  <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. -->
                  swfobject.createCSS("#flashContent", "display:block;text-align:left;");
              </script>
      In the mxml file:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:mod="mod.*"
                  applicationComplete="readParams(event)"
          layout="vertical" height="100%" width="100%">
                  protected function readParams(event:Event) : void {
                      var userId:String;
                      var authToken:String;
                      var subjectParams:Object = root.loaderInfo.parameters;
                      for (var subjectParam:String in subjectParams) {
                          userId = subjectParams["userId"];
                          authToken = subjectParams["authToken"];
                      //userId = root.loaderInfo.parameters.userId;
                      Alert.show ("\t" + "userId value" + ":\t" + userId + "\n" +
                          "\t" + "authToken value" + ":\t" + authToken + "\n"    );
      However, seems like this part of the code is not working:
      because instead of the values passed these variables, my app reads
                < userId
                < authToken
      if I use values which are fixed, it works fine e.g.
                flashvars.userId = "smith";
      Your help will be much appreciated
      Thank you.
