2 Replies Latest reply on Oct 29, 2010 3:25 PM by Stenrap2
    Call javascript from AIR
    Stenrap2 Level 1
      Hi all,
      I'm having a hell of a time trying to call JavaScript from an AIR application. Here's what I'm trying to do:
      1. Load an HTML page using HTMLLoader.
      2. Access a link by its ID in the HTMLLoader object and simulate the JavaScript click() function on that link.
      I've tried lots of approaches, but here's the latest code that fails:
        • 1. Re: Call javascript from AIR
          Stenrap2 Level 1
          Accidently submitted my post with some keyboard combination.
          Here's the JavaScript function in the loaded HTML page (it simply submits a form on the page):
          function submitAssistantForm(direction)
          And here's the ActionScript code I'm trying:
          var html:HTMLLoader = new HTMLLoader();
          html.addEventListener(Event.COMPLETE, splash);
          html.load(new URLRequest("...URL omitted..."));
          private function splash(e:Event):void
              // try to access the element by its ID and call the Javascript click() function on it
              html.window.document.getElementById('HrNext').click(); // this gives error "click is not a function"
              // try to call the Javascript function directly by its name
              html.window.submitAssistantForm('next'); // this gives error "TypeError: Result of expression 'document.theForm' [undefined] is not an object."
          By the way, if I add the HTMLLoader object to the stage and manually click the link with my mouse everything works perfectly (so I have to believe it's possible to programmatically send a click event to the link). I feel like I'm so close. Can anyone point me in the right direction?
          • 2. Re: Call javascript from AIR
            Stenrap2 Level 1
            In case this helps anyone else, I figured out one way to do it. Just  set the value of window.location to the href value of the link:
            <code>html.window.document.location =  "javascript:submitAssistantForm('next');";</code>
