1 Reply Latest reply on Oct 29, 2010 4:37 PM by The Flex Viking
    Calculate Value From XML in Table Row
    The Flex Viking Level 1
      I am binding an XML document to an XDP to generate a PDF.  The XML contains repeating data.  I have created a Table with the BodyRow set to repeat for each data item to display the repeating data.
      Let's assume my repeating XML looks like
      <Person>
        <FirstName />
        <MiddleName />
        <LastName />
        <Address />
        <City />
        <State />
        <ZipCode />
        <Telephone />
        <EmployeeID />
      </Person>
      So, I have the BodyRow configured to bind to $.Staff.Person[*].  And then each TextField in the BodyRow is bound to something like $.Telephone.  Easy.
      Now.  Let's say I want to define a new column that is a calculated value.  Say I want to generate something like LastName +  FirstName + Middle Initial + EmployeeID and neither Middle Initial or EmployeeID is bound in the table row.  I want to use FormCalc (or JavaScript) to calculate the value.  My plan was to use the calculate event on the TextField in the BodyRow.  However, I can't seem to figure out how to access the data relative to the current row.  How do I do that?
      I've been looking around the web and can't seem to place my finger on this and I assume this is not an uncommon need.
      Do I create "hidden" columns and access the data that way?
        • 1. Re: Calculate Value From XML in Table Row
          I am not sure if this is the best way, it uses an absolute lookup of the value.  I would think I could used a relative lookup in relation to each row ....but, this works ...
          Use a calculate script for the TextField that needs the calculated value
          var index = $.parent.index
          $ = Concat($data.Staff.Person[index].LastName, $data.Staff.Person[index].EmployeeID)
