I have XML that looks like this
<rsp>
<videos total="39" >
<video id="565455" title="With Love" />
</videos>
</rsp>
I'm trying to dispay the xml using coldfusion. I've done this before but the problem i have this time is trying to access the id and title values in the video.
Can someone give me a simple example of retrieving this?
I have:
<cfset mydoc = XmlParse(CFHTTP.FileContent)>
<cfset pb = mydoc.rsp.XmlChildren>
<cfset size = ArrayLen(pb)>
<cfset myquery = QueryNew("id, title")>
<cfset temp = QueryAddRow(myquery, #size#)>
<cfloop index="i" from = "1" to = #size#>
</cfloop>
Sorry if my cf is so bad!!
Have a look @ XPath & xmlSearch().
A good beginners' tutorial on XPath:
http://www.zvon.org/comp/r/tut-XPath_1.html
xmlSearch() docs:
http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-78e8.html
Have you also read the XML section of the CF docs?
http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec22c24-7fb3.html
It pretty-much covers everything (... OK... most things...) you need to know about accessing/addressing XML data with CF.
Probably in this case - if your XML really is that straight fwd, I'd just access the values directly with dot-notation, as per the CF docs above, in which it's all explained.
Adam
Hi Adam, Thanks so much.
I couldnt find how to access a value inside the tag.
Could you send me to a direct example. I think the info is little over my head.
Did the stuff here - http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec133ba-7fe6.html#WSc3ff6d0ea77859461172e0811cbec22c24-78e9 - not make sense?
What did you try? Where's some code that you tried?
I'm not one to just give people "direct" answers here, sorry: I don't believe that this helps much.
However I'm happy to help you work through it, if you give it a go yourself.
Adam
My code is up there. I just don't know how to retrieve the value of the attribute.
In this example, how can I figure it out without seeing the XML that coldfusion is parsing
Sorry the xml document is on the page. Let me take another look
This is what I have now
<rsp>
</videos>
</rsp>
<cfset temp = QuerySetCell(myquery, "id", #mydoc.videos.video[1].XmlAttributes["id"]#, #i#)> Error here
<cfset temp = QuerySetCell(myquery, "title", #mydoc.videos.video[1].XmlAttributes["title"]#, #i#)>
</cfloop>
I'm getting this error:
I think the problem is the XML doc I'm parsing has an extra parent <rsp>
You have two problems in the code you've posted.
1. The size variable you've defined will contain the number of children for the "rsp" node which is one, "videos". You want to get the number of "video" elements.2. When using element names you can put them in square brackets with quotes.See code below.Copy link to clipboard
Thanks. At this line
<cfset size=ArrayLen(mydoc["rsp"]["videos"]["video"])> <!--- get number of video elements --->
I'm getting:
<cfset mydoc = XmlParse(CFHTTP.FileContent) />
<cfoutput>id: #mydoc["rsp"]["videos"]["video"].XmlAttributes["id"]#</cfoutput >
</cfloop>
I am not able to re-create the error using the code below. I suspect that the XML contained in the CFHTTP.FileContent variable does not match the sample you provided.
<!--- use CFSAVECONTENT instead of CFHTTP --->
<cfsavecontent variable="fileContent"><?xml version="1.0" encoding="utf-8"?>
<rsp>
<video id="12345" title="Item Two" />
</videos>
</rsp>
</cfsavecontent>
<cfset mydoc = XmlParse(fileContent)>
<cfoutput>id: #mydoc["rsp"]["videos"]["video"].XmlAttributes["id"]#</cfoutput>
</cfloop>
I'm wondering if maybe the API key is failing and that's why it's not bringing it up. I'll check this out.
Those colons are called namespaces.
http://www.aftergeek.com/2006/08/xmlsearch-xpath-and-xml-namespaces-in.html
Dave Watts, CTO, Fig Leaf Software
http://www.figleaf.com/
http://training.figleaf.com/
Fig Leaf Software is a Veteran-Owned Small Business (VOSB) on
GSA Schedule, and provides the highest caliber vendor-authorized
instruction at our training centers, online, or onsite.
Read this before you post:
http://forums.adobe.com/thread/607238
