1. Re: z-index issues with acrobat plugin
lrosenth Nov 1, 2010 7:11 AM (in response to jmurphy777)Yes, this is a known issue.
2. Re: z-index issues with acrobat plugin
jmurphy777 Nov 1, 2010 3:09 PM (in response to lrosenth)short and sweet,
but is there a work around?
3. Re: z-index issues with acrobat plugin
lrosenth Nov 1, 2010 3:14 PM (in response to jmurphy777)Nope. (or I would have suggested it)
4. Re: z-index issues with acrobat plugin
james_ladd Nov 4, 2010 10:36 PM (in response to jmurphy777)Did you get any further with this issue?
5. Re: z-index issues with acrobat plugin
jmurphy777 Nov 10, 2010 1:59 PM (in response to james_ladd)nope....
that was everything, exausted the knowledge base aparrently...
will have to revert to a javascript code instead...
just not handy due to ease of use of the plugin.
Unless you know anything....
6. Re: z-index issues with acrobat plugin
jmurphy777 Feb 16, 2011 8:19 PM (in response to jmurphy777)has this issue been changed the new adobe reader plugin?
7. Re: z-index issues with acrobat plugin
lrosenth Feb 17, 2011 6:53 AM (in response to jmurphy777)It's a problem with the browsers, not with Adobe Reader....
8. Re: z-index issues with acrobat plugin
jmurphy777 Feb 17, 2011 2:21 PM (in response to lrosenth)but if it is a known issue, and we know that Microsoft isnt going to change their coding style, doesnt the premise then fall back to adobe to accomodate?
9. Re: z-index issues with acrobat plugin
lrosenth Feb 17, 2011 8:15 PM (in response to jmurphy777)If it were possible - sure. But it's entirely up to them, since they control the menus and where they draw.
10. Re: z-index issues with acrobat plugin
subinvarghesein Mar 28, 2011 3:48 AM (in response to lrosenth)There is an attribute/parameter called wmode which could be set to 'opaque' or 'transparent' to solve the issue for Adobe Flash content. This attribute is provided by Adobe itself. Then why is this not provided for Adobe Reader plugin?
By providing this attribute, it means that the stacking order of the flash content is controlled by Flash plugin. Isn't this the case for the Adobe Reader also?
11. Re: z-index issues with acrobat plugin
lrosenth Mar 28, 2011 8:06 AM (in response to subinvarghesein)No, it is not the case with Reader also.
12. Re: z-index issues with acrobat plugin
Sampath Liyanage Dec 26, 2013 11:09 PM (in response to lrosenth)Is it fixed or still have this same issue, because I also got this z-index issue
