3 Replies Latest reply on Nov 7, 2010 9:44 AM by tim494
    Zend Amf : mapping a PHP Array to a Flex ArrayCollection
    tim494
      I would like to know if it is now possible to  map a PHP Array to a Flex ArrayCollection via Zend Amf, without using  any workaround.
      I have quite the same issue that has been reported  here (about one year ago) :  http://forums.adobe.com/thread/495999?decorator=print&displayFullThread=true
      It seems like it was a bug so I was wondering if it is supposed to work now because i'm still having the problem.
      It  works with Gaurav's workaround  (http://forums.adobe.com/message/2267088#2267088) which consists in  sending a Zend_Amf_Value_Messaging_ArrayCollection object instead of an  Array on the server side, but I was hoping I could get rid of the  workaround...
      Thanks in advance
      Tim
        • 2. Re: Zend Amf : mapping a PHP Array to a Flex ArrayCollection
          AdobeFlex1
          ..try to use ArrayUtil.toArray():
          import mx.utils.ArrayUtil;
          private var people:ArrayCollection = new ArrayCollection();
          protected function getPeopleInMyWorldResult_resultHandler(event:ResultEvent):void {
               people =  new ArrayCollection(ArrayUtil.toArray(event.result));
          • 3. Re: Zend Amf : mapping a PHP Array to a Flex ArrayCollection
            tim494 Level 1
            Hello,
            This would surely work but it is not exactly what I need.
            In fact, I send an array from PHP, and since my value object property on the AS3 side is typed to an ArrayCollection, Zend Amf should automatically cast my Array into an ArrayCollection. That's what Zend Amf does, you send a custom object from the server side, it creates the corresponding object on the client side.
            My PHP Classes :
            class FileSystemItem
                 public $name;
                 public $parentFullPath;
                 public $createdOn;
                 public $lastAccessedOn;
                 public $lastModifiedOn;
            class FolderItem extends FileSystemItem
                public $content = array();
            class FileItem extends FileSystemItem
                public $size;
            The FileSystemItem represents either a folder or a file and initializes the common properties in its constructor.
            The FolderItem represents a Folder. It extends the FileSystemItem class with a "content" property which is an array containing FolderItem objects or FileItem Objects. The FolderItem class has a "loadContent" method to fill the content array.
            The FileItem represents a File. It extends the FileSytemItem class with a "size" property.
            Here are the corresponding AS3 classes used by Zend Amf to do the mapping :
            package valueObjects
                [RemoteClass(alias="FileSystemItem")]
                [Bindable]
                public class FileSystemItem
                    public var name:String;
                    public var parentFullPath:String;
                    public var createdOn:String;
                    public var lastAccessedOn:String;
                    public var lastModifiedOn:String;
                import mx.collections.ArrayCollection;
                [RemoteClass(alias="FolderItem")]
                [Bindable]
                public class FolderItem extends FileSystemItem
                    public var content:ArrayCollection = new ArrayCollection();
                [RemoteClass(alias="FileItem")]
                [Bindable]
                public class FileItem extends FileSystemItem
                    public var size:int;
            I simplified my application to the minimum, it is just calling a service method to get a FolderItem with its content.
            protected function init():void
                 var initTreeToken:AsyncToken = FileSystemBrowser.getFolder("C:/", "flexworks");
                 initTreeToken.addResponder(new mx.rpc.Responder(getFolder_initResultHandler, getFolder_faultHandler));
            protected function getFolder_initResultHandler(event:ResultEvent):void
            It works fine until then :
            The problem occurs when the event.result property is populated, so I don't even get the chance to create an ArrayCollection from the received Array and put it into my "content" AS3 object property. It throws those errors (btw I wonder why there are four errors and not just one) :
            TypeError: Error #1034: Echec de la contrainte de type : conversion de []@7868269 en mx.collections.ArrayCollection impossible.
            TypeError: Error #1034: Echec de la contrainte de type : conversion de []@bc2ef39 en mx.collections.ArrayCollection impossible.
            I hope you see more clearly what I mean now...
            Thank you for trying to help me.
            Message was edited by: tim494
