3 Replies Latest reply on Nov 2, 2010 3:10 PM by Devtron
    parts of XML in hierachical data (like a tree)
    Manno Bult-to3djt
      Hi all,
      I have a potential rather large XML file of which I would like to present only parts in a tree structure. The XML is something like:
      <scenes>
           <scene id="1" label="a label">
                <actors>
                     ... stuff ...
                </actors>
                <snapshots>
                     <snapshot label="a label">
                          ... content of node ...
                     </snapshot>
                     <snapshot label="aother label">
                     </snapshot>
                     ... possibly more snapshots ...
                </snapshots>
           </scene>
           <scene label="a">
                <actors>
                     ... stuff ...
                </actors>
                <snapshots>
                     </snapshot>
                     </snapshot>
                </snapshots>
           </scene>
           ... more scenes ...
      </scenes>
      I would like to have a tree-like representation of it so that only 'scene' labels and 'snapshot' labels are shown.
      I can't figure out how to ignore all the subnodes without actually creating a copy of the XML and stripping them in some way. This I'd rather not do since the link between the actual data and it's visualization ( the tree ) is more or less gone.
      Suppose I'm a bit confused by all the possibilities... Maybe I can use a stripped XML but bind selections or changes (node's labels should be possible to be renamed and reordered) to the original data?
      Can someone point me in a right direction?
      Thanks in advance.
      Manno
        • 2. Re: parts of XML in hierachical data (like a tree)
          Manno Bult-to3djt Level 2
          Short but (/and?) spot on
          With some online examples it works ( in it's basic form ), now into the main thing...
          • 3. Re: parts of XML in hierachical data (like a tree)
            Devtron Level 3
            Wow, I wish I had known about [ITreeDataDescriptor] beforehand!!
            Another way to approach this is to assign the XML to an ArrayCollection and loop through the ArrayCollection, parsing out the strings you need.
            I was able to do this relatively easily to produce custom XML for my Trees (which use checkboxes in them!). It only took me a few hours and I thought it would take me weeks.
                            var XMLStr:String = "<accounts>\n";
                            for each(var XMLNodeObj:Object in treeAC) {
                                        //if AccountID is not found in the new XML, process forward to obtain it
                                        if (XMLStr.search("AccountID=\"" +  XMLNodeObj.AccountID  ) == -1 ) {
                                              XMLStr += "<account label=\"" +  XMLNodeObj.AccountName + "\" AccountID=\"" +  XMLNodeObj.AccountID + "\" checked=\"0\"> \n"
                                              //getTreeAccountLocationXML is a string function that performs a search for other XML attributes needed
                                              XMLStr += getTreeAccountLocationXML(XMLNodeObj.AccountID ,treeAC);
                                              XMLStr += "</account> \n"
                           //XML end tag
                           return XMLStr += "</accounts>"
            this code "checked=\"0\"> \n" " sets the "checked" property, which produces a checkbox in my Tree control for me....pretty damn cool.
