2 Replies Latest reply on Nov 2, 2010 12:46 PM by locollama
    How do you put a value in a text field a value of a nested array?
    locollama Level 1
      Hello,
      Im a newbie and was trying out some sql queries.
      I am selecting one column from a table.  If put the results into a datagrid the values show up, however.
      if I assigned the results to an Array and try to access the results via row and column i get this.
      var r:SQLResult = SQLStatement(event.currentTarget).getResult();
                  //    dg.dataProvider = r.data;
                      IndexArray = r.data;
                      var temp:Object=r.data[0][0];
                      testtext.text=temp.toString();
      all i get in the testtext.text field is [obejct Obeject].
      How can i retrieve the actual value?
      thanks for any help.
