2 Replies Latest reply on Nov 2, 2010 11:19 AM by Whitetimer
    What do you datatype a color as ?
    Whitetimer Level 1
      Hi All
      Silly question, but if i create a var called BackgroundColor:<DATATYPE> = #000099 for example
      what datatype would i use ?
      many Thanks
        • 1. Re: What do you datatype a color as ?
          anomicbomber
          Heya,
          You would most definately store that as an unsigned integer (uint) in most contexts.
          In  ActionScript 1 and 2, I do believe there was a Color class, but in  ActionScript 3.0, the ColorTransform data type kinda took over, but I  don't think you want to use that for what seems to be a simpler purpose.
          So, for uint's, though:
          public const MY_BLUE:uint = 0x0354FF;
          obj.setStyle("color", MY_BLUE);
          If  you're familiar with hexadecimal, this answer should make sense to you,  otherwise, Wikipedia does a good job explaining that lovely number  system. Haha.
          Hope that helps!
          • 2. Re: What do you datatype a color as ?
            Whitetimer Level 1
            Hi
            Thanks for the reply and advice.  The plan was to bind a components variable to the custom variable
            ie.
            public var borderLabelBackgroundColor:uint = 0x000099;
            <s:BorderContainer id="BorderLabel" backgroundColor="{borderLabelBackgroundColor}" borderVisible="true" />
            Is this way ok or is there a better method ?
            Many thanks
            P.S
            When i try this way, i get the following error
            [iuwth] Data binding will not be able to detect assignments to "borderLabelBackGroundColor"
            Any thoughts ?
