Hi, After recording in FMR mode, to stop capturing I press <End> key. This brings up a 'Creating Slides and Objects...' window, which becomes part of the FMR slide. I then have to trim that end bit. Is this how it should work? Or can I suppress this message from appearing in the FMR slide?
thanks,
mike
Hello,
I never do a full recording in FMR, but perhaps could offer a suggestion: if you record in manual or custom mode, you can use F9 to start FMR. If you switch back to normal mode by using F10 immediately before ending the capture?
Those shortcuts are for Win, for Mac it is Command-F9 and Command-F10
Lilybiri
Hi Mike,
As of yet you cannot. But if you think that should be the way going forward then please send us a feature request.
-Manish
blogs.adobe.com/captivate
