This content has been marked as final.
Show 1 reply
1. Re: LR3 and Photoshop CS5
Jeff Schewe Nov 2, 2010 12:31 PM (in response to nufarydyna)Since you have version parity (LR 3.3 and ACR 6.3) there is no need to see the warning dlog regarding rendering. Also note that since there is parity between the versions there is no reason to try to open a raw file from Lightroom in Camera Raw. The rendering is identical (although the usability is slightly different). Do the raw work in Lightroom and then open the file in Photoshop using its toolset. The only time you might consider combining Lightroom and Camera Raw is when you open an image in Photoshop as a Camera Raw Smart Object...there you can use both Lightroom then the Smart Object version of Camera Raw together...
