4 Replies Latest reply on Nov 4, 2010 11:22 AM by dpmsr
    W3C Warnings
    dpmsr
      Hello,
      I have a RoboHelp 7 WebHelp project which I want to convert to Rh8.  The project opens fine and I can generate the WebHelp output which looks good although I haven't tested 100%. I ran the W3C compliance option and received numerous Warnings (no errors) on most of my topics.  Can someone tell me or direct me to whereI can determine the impact of these Warnings (below)?  They appear to be related to the XHTML and from what I can tell are pointing to embedded links, bookmarks etc.
      I have some updates to make to existing topics and I want to be sure I am not missing something or introducing a problem when I redeploy the project as Rh8.
      Thank you
      <a> escaping malformed URI reference
      <a> attribute "name" has invalid value "<value>"
      <a> cannot copy name attribute to id
        • 1. Re: W3C Warnings
          Willam van Weelden Level 5
          As far as I know:
          Your url in a link uses backslashes (..\) instead of slashes (../). Your project will probably keep working. No impact for RH8, as RH8 sometimes uses backslashes itself.
          A bit cryptic, but does the value have <> in it? If so, these characters may confuse browsers, because HTML tags are placed inside those brackets. You would best amend those values.
          The "name" and "id"  attribute are not the same. No impact that I know of, only creates harder to read code. An id must be unique and a name is used to uniquely identify an element or a set of related elements. So if you have element x with id 'a' and name 'b' and an element y with id 'b' and name 'a', it may get confusing if you look at the HTML.
          Greet,
          Willam
          • 2. Re: W3C Warnings
            dpmsr Level 1
            Thank you William,
            That is quite helpful, I will have to look at the code closer with someone a bit more familiar with HTML.
            As far as the second 'cryptic' concern, my bad, the value does not include the braces (<>). In this case any idea what the warning may be?
            Thank you again
            Dave
            • 3. Re: W3C Warnings
              Sorry for the delay. My guess is that you use invalid characters in the attribute. I'm not sure what is and what isn't allowed, but starting with a number may cause problems.
              Greet,
              Willam
              • 4. Re: W3C Warnings
                dpmsr Level 1
                Thanks you William.  I did have one of our developers look at your prior response and review the associate warnings.
                It does not appear there is any critical impact.
                Much obliged,
                Dave
