23 Replies Latest reply on Jan 4, 2011 3:12 AM by wttewaall
    XML namespaces changed to aaa when exporting xml doc in AIR app
    BKUoP Level 1
      When I export my xml in a TimedText Format from an AIR application I'm working on, the xml namespaces get changed to aaa instead of xml...does anyone know how to fix this or keep the application from changing them arbitrarily.
      One other question, for some reason the code I have, as formatted now, will not let me use the appendChild method to add my cuepoints to the TTF xml document.
      Any advise would be greatly appreciated.  My code is below:
                     //Create final XML
                      private function submit():void
                          if (boolVideoSelected == true)
                              xmlData =
                                  <tt xml:lang="en" xmlns="http://www.w3.org/2006/04/ttaf1" xmlns:tts="http://www.w3.org/2006/04/ttaf1#styling">
                                      <head>
                                          <styling>
                                              <style id="1" tts:textAlign="center" tts:backgroundColor="gray" tts:color="white" tts:fontSize="14" tts:fontFamily="sansSerif" />
                                          </styling>
                                      </head>
                                      <body>
                                          <div xml:lang="en" style="1">
                                          </div>
                                      </body>
                                  </tt>;
                              var cue:XML;
                              var strTempDuration:String;
                              var strTempTime:String;
                              var strTempContent:String;
                              vidVideo.pause(); //Pause video
                              btnPlay.label = ">";
                                 for (var i:int = 0; i < stateArray.length; i++) //Convert stateArray into XML
                                     strTempDuration = stateArray[i].duration.toString();
                                     strTempTime = stateArray[i].time.toString();
                                     strTempContent = stateArray[i].content.toString();
                                     cue = <p begin={strTempTime} dur={strTempDuration}>{strTempContent}</p> //Generate cue
                                     //trace(xmlData);
                                     xmlData.body.div.appendChild(cue); //Insert cues into XML sequentially
                                 xmlFile = new File;
                                 xmlFile.browseForSave("Save XML File"); //Open browse window for save location
                                 //Event listeners
                                 xmlFile.addEventListener(Event.SELECT, xmlFileSelectHandler);
                              xmlFile.addEventListener(IOErrorEvent.IO_ERROR, ioHandler);
                              xmlFile.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityHandler);
                      private function xmlFileSelectHandler(e:Event):void {
                          var newFile:File = e.target as File;
                          if(!newFile.extension || newFile.extension != "xml") //Check if .xml was included in user entry
                              newFile.nativePath += ".xml"; //Add .xml to the filename if it was not included
                          var stream:FileStream = new FileStream();
                          stream.open(newFile, FileMode.WRITE);
                          stream.writeUTFBytes(xmlData.toString()); //Write XML string to XML file
                          stream.close();
