This content has been marked as final.
Show 6 replies
1. Re: Flash Form and Navigation Button Issue (DoFSCommand)
bryn50 Jul 25, 2007 1:20 PM (in response to bryn50)Replying to my own posts again...
the answer came in the Flex 1.5 documents for Actionscript 3 (I assume this is what CF 8 has behind the scenes).
The doc says:
"In ActionScript 3.0, the functionality of the External API is provided by the ExternalInterface class."...
"If you need to use the old fscommand() function--for example, to maintain compatibility with older applications or to interact with a third-party SWF container application or the stand-alone Flash Player--it is still available as a package-level function in the flash.system package."
However I'd like to make the point that no-where anywhere in the CF documentation is even one tiny example of the use of action script coding to enhance the basic functionality of CFForm. To much to ask ?
Oh yes, and one other thing, it seems as though the getURL actionscript command does what I needed to do in this case.
Cheers,
2. Re: Flash Form and Navigation Button Issue (DoFSCommand)
Alain Levy-s3SmK8 Aug 9, 2007 11:14 AM (in response to bryn50)Hi,
In relation to communication issues between Flash and Javascript: I am trying to get Javascript to talk to my Flash form, but I can't get it to work.
I would like at least to be able to change the value of a hidden field in my form, or even better to execute an actionscript function, from Javascript.
I believe the answer lies somewhere around the ExternalInterface.addCallback function, but I just can't get it to work.
I am trying to do this because I have a flash form with a tab navigator and the showing tab is bound to a hidden field.So far so good...I am now trying to use the new CF8 CFmenu functionality to control which tab shows. That's why I need it!
Any guidance appreciated! Thanks a lot!
Alain -
3. Flash Form and Navigation Button Issue (DoFSCommand)
bryn50 Aug 9, 2007 11:28 AM (in response to Alain Levy-s3SmK8)Hi Alain,
Not sure if I can help directly however I found the following.
a) biggest issue was deciding which version of actionscript documentation to read. I decided upon Flex Actionscript version 1.5 and this seems to hold out, even with CF8. Not happy with Adobe's lack of any kind of example for actionscripting within CFFORM/Flash which would have helped just to get me started. I found not even one tiny example in all the docs I read.
b) I never got javascript talking to the flash form or vice-versa. I went for purely actionscript within the flash form and it seems to work.
c) I can see why you need it to work, and if you find out please let me know, I will be fascinated as I had in mind to do some things like that for my own App (e.g. I suspect will sooner or later not be able to avoid this issue myself.).
Cheers and best of luck..
BP. -
4. Flash Form and Navigation Button Issue (DoFSCommand)
bryn50 Aug 9, 2007 12:45 PM (in response to Alain Levy-s3SmK8)Try the attached script.
I remain convinced that for some reason Adobe have nobbled (technical term) the functioning of the external interface in flash <cfform>s Dont know why, but unexplained.
Neither externalinterface nor fscommand seem to work as best I can tell. (see attached).
Interestingly mx.external.ExternalInterface.available does seem to get a 'false' return value (instead of an error message like flash.external.ExternalInterface gets you.).....
Like I say, if you happen to crack this one, please do let us all know. ;-))
Cheers,
BP -
5. Re: Flash Form and Navigation Button Issue (DoFSCommand)
Alain Levy-s3SmK8 Aug 9, 2007 3:32 PM (in response to bryn50)Hi, and thanks +++ for your reply and the code... I can't get it to work either, it drives me mad...
I wish asfusion would get their teeth on it, they are just the best! Unfortunately, they are not much into flash forms these days, just flex...
Will keep you posted - and everyone else! - if I can get it to work!
Alain -
6. Re: Flash Form and Navigation Button Issue (DoFSCommand)
jepoy1 Oct 25, 2011 2:15 AM (in response to Alain Levy-s3SmK8)hi,
i have the same problem also...on how to communicate normal button to cfinput button. Did you find out how to solve this?
Pls let me know. Many thanks,
I just want to click the button of cfform flash using a normal button outside.
Jeff
