2 Replies Latest reply on Jul 16, 2007 7:00 AM by
    passing data on click event
      I hope I can explain this well. I've built a set of movable thumbnails that is basically a VBox with an image and text field in it. I based it off of the flexstore sample application. Inside the component's script I declare a public variable called comp. It contains the name of the corresponding viewstack view. When the thumbnail component is clicked I need to update my viewstack with this variable's name. I'm getting the variable by calling event.target.comp from the mouseclick event. The code works fine as long as I don't click on the image or text box. Otherwise it tells me the comp is not defined and there is no default value. How can I make it so that no matter where I click inside the thumbnail component, it returns this value to me?
      Site with source is available here
