2 Replies Latest reply on Nov 2, 2010 11:13 PM by hi-adobe
    changing a single value across a set + corner pin stabilization
    hi-adobe
      a few questions that have been hounding me...
      is it possible to change a single variable X across a set of keyframes while still retaining each frames Y value?...when I select all and change the X and hit enter, the Y is also changed for every keyframe.
      can mocha export the X or Y translation value exclusively like the AE tracker?
      how do you use the mocha corner pin data to stabilize a shot?  (there are like a hundred tutorials on replacing billboards, but only a few on the intricacies of stabilization...)
      my appreciation if you can enlighten me.
