How is memory handled by Flash Lite when we load an image from an external folder into an application?
Basically the same image is loaded 2 times (one as a thumbnail, one as a full image), but by different classes. In this case, will Flash Lite treat each image instance as separate image while blocking memory? Or because the image is the same, although it is loaded twice by 2 separate classes, the memory will be calculated for one image only?
Regards,
Mariam
