0 Replies Latest reply on Nov 3, 2010 11:08 AM by jvenkatrao
    Process with RenderPDFForm using Java API not generating output file
    jvenkatrao Level 1
      I have a short-lived process that renders a PDF/HTML form based on input parameters. It also takes a .xdp file as input. This works just fine from with
      in Workbench (9.0). I have created a Java client to invoke this process. When I invoke the process from the Java Client,
      it is not creating the output file. When I look at the invocation response, I see the output parameter (output file) name, but it is null.
      Here is my code.
      Properties connectionProps =
      new Properties();
      connectionProps.setProperty(
      "DSC_DEFAULT_SOAP_ENDPOINT", "http://hostname:8080");
      "DSC_TRANSPORT_PROTOCOL","SOAP");
      "DSC_SERVER_TYPE", "JBoss");
      "DSC_CREDENTIAL_USERNAME", "username");
      "DSC_CREDENTIAL_PASSWORD", "password");
      //Create a ServiceClientFactory object
      ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
      //Create a ServiceClient object
      ServiceClient myServiceClient = myFactory.getServiceClient();
      //Create a Map object to store the parameter value
      Map params =
      new HashMap();
      File file =
      new File("C:/test1/test.xdp");
      File ofile =
      new File("C:/TestProcess.pdf");
      //String formName = "RD410-4.xdp";
      InputStream inFile =
      new FileInputStream(file);
      OutputStream oFileStream =
      new FileOutputStream(ofile);
      byte[] cData = "".getBytes();
      Document inputData =
      new Document(inFile);
      // Document outputData = new Document(oFileStream);
      inputData.passivate();
      params.put(
      "Form", inputData);
      params.put(
      "FormId", "12");
      params.put(
      "RevId", "12");
      params.put(
      "OutputType", "PDF");
      params.put(
      "targetSubmission", "http://localhost:8090/LCWebProject/HandleData");
      params.put(
      "param1",1);
      InvocationRequest invokeRequest = myFactory.createInvocationRequest(
      "MyApplication10/Processes/RenderForm", //Specify the short-lived process name
      "invoke", //Specify the operation name
      params,
      //Specify input values
      true); //Create a synchronous request
      InvocationResponse invokeresponse = myServiceClient.invoke(invokeRequest);
      Document encryptDoc = (Document) invokeresponse.getOutputParameter(
      "outputFile");
      //Save the encrypted PDF document returned by the process
      //Save the password-encrypted PDF document
      File outFile =
      new File("C:\\test1.pdf");
      encryptDoc.copyToFile (outFile);
      I see the output parameter "outputFile" in the invokeresponse object. But it is null.
      Can anyone guide me in the right direction ?
      Jyothi
