10 Replies Latest reply on Nov 11, 2010 7:19 AM by stephenure
    Error message in IE when viewing output. whskin_tbars.htm
    stephenure Level 1
      ROBOHELP HTML 8.
      Hello,
      I generate my webhelp files. Add them to the application file. Build, Deploy, etc,
      Then when accessing the help file directly or through the application(web application) using Internet Explorer 8, I get an error...
      Webpage error details
      User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.2; Tablet PC 2.0; .NET4.0C; .NET4.0E)
      Timestamp: Wed, 3 Nov 2010 19:07:56 UTC
      Message: Expected ';'
      Line: 21
      Char: 12
      Code: 0
      URI: https://vmgenqa03/MeiTpm/help/ENG/whskin_tbars.htm
      It still loads the help and goes away when you start navigating, But what is causing it and how can I get rid of it?
      Does not happen in Firefox, but we only support IE.
      Stephen
        • 1. Re: Error message in IE when viewing output. whskin_tbars.htm
          stephenure Level 1
          Anybody got any ideas? Mr. Grainge?
          • 2. Re: Error message in IE when viewing output. whskin_tbars.htm
            perttime Level 1
            Does your 'whskin_tbars.htm' file have anything on Line 21, or thereabouts?
            (open it in Notepad or some other text editor)
            • 3. Re: Error message in IE when viewing output. whskin_tbars.htm
              stephenure Level 1
              line 21 is...
              var history.go = function(-1)
              • 4. Re: Error message in IE when viewing output. whskin_tbars.htm
                Willam van Weelden Adobe Community Professional & MVP
                history.go is a javascript function. You cannot declare this as a variable. Can you post the complete script so we can check what this code tries to do? My guess is that this is the code for a back button. Try replacing this line with: history.go(-1); (If you're doing something else, don't replace this line.)
                Greet,
                Willam
                • 5. Re: Error message in IE when viewing output. whskin_tbars.htm
                  stephenure Level 1
                  Hi William,
                  Thanks for you help. Here is the whole file...
                  <html>
                  <head>
                  <title> WebHelp Navigation Toolbar </title>
                  <meta name="generator" content="Adobe RoboHelp 8" />
                  <meta name="description" content="WebHelp 5.50" />
                  <style>
                  body {margin:0;}
                  </style>
                  <script language="javascript" src="whver.js"></script>
                  <script language="javascript1.2" src="whutils.js"></script>
                  <script language="javascript1.2" src="whmsg.js"></script>
                  <script language="javascript1.2" src="whproxy.js"></script>
                  <script language="javascript1.2" src="whmozemu.js"></script>
                  <script language="javascript1.2" src="whtbar.js"></script>
                  <script type="text/javascript" language="JavaScript1.2">
                  //<![CDATA[
                  var topicPane = top.frames[1].frames[1];
                  topicPane.focus(-1);
                  topicPane.history.go(-1);
                  </script>
                  </head>
                  <body marginheight="0"  marginwidth="0"  bgcolor="White"     scroll="no">
                  <script language="javascript1.2">
                  if (window.gbWhTBar)
                      setButtonFont("toc","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("toc","Verdana","8pt","#333333","Normal","Bold","none", true);
                  setButtonFont("idx","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("idx","Verdana","8pt","#333333","Normal","Bold","none", true);
                  setButtonFont("fts","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("fts","Verdana","8pt","#333333","Normal","Bold","none", true);
                  setButtonFont("glo","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("glo","Verdana","8pt","#333333","Normal","Bold","none", true);
                  setButtonFont("searchform","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("searchform","","","","","","", true);
                  setButtonFont("banner","","","","","","");
                  setButtonFont("banner","","","","","","", true);
                  setButtonFont("custom9412","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("custom9412","Verdana","8pt","#333333","Normal","Bold","none", true);
                  setButtonFont("custom24912","Verdana","8pt","#333333","Normal","Bold","none");
                  setButtonFont("custom24912","Verdana","8pt","#333333","Normal","Bold","none", true);
                      gsIToc = "wht_toc_n.gif";
                      gsITocS = "wht_toc_h.gif";
                      gsIIndex = "wht_idx_n.gif";
                      gsIIndexS = "wht_idx_h.gif";
                      gsISearch = "wht_fts_n.gif";
                      gsISearchS = "wht_fts_h.gif";
                      gsIGlossary = "wht_glo_n.gif";
                      gsIGlossaryS = "wht_glo_h.gif";
                      gsIWebSearch = "wht_ws.gif";
                      gsIWebSearchD = "wht_ws_g.gif";
                      gsIBanner = "wht_logo1.gif";
                      gsIGo = "wht_go.gif";
                      setBackgroundcolor("White");
                      setAlignment("left");
                      setGoImage("search.png");
                      if (!gsBgImage)
                      setButtonBgColor("toc", gsBgColor);
                      setButtonBgColor("idx", gsBgColor);
                      setButtonBgColor("fts", gsBgColor);
                      setButtonBgColor("glo", gsBgColor);
                      setButtonBgColor("toc", gsTBSelectedBgColor, true);
                      setButtonBgColor("idx", gsTBSelectedBgColor, true);
                      setButtonBgColor("fts", gsTBSelectedBgColor, true);
                      setButtonBgColor("glo", gsTBSelectedBgColor, true);
                      setButtonBgColor("toc","White");
                  setButtonBgColor("idx","White");
                  setButtonBgColor("fts","White");
                  I did add a backbutton through the skin editor with the following commands...
                  Stephen
                  • 6. Re: Error message in IE when viewing output. whskin_tbars.htm
                    In the skin editor, modify the code of your back button to:
                    top.frames[1].frames[1].history.go(-1);
                    That should clear up your error message and make your back button functional.
                    Greet,
                    Willam
                    • 7. Re: Error message in IE when viewing output. whskin_tbars.htm
                      stephenure Level 1
                      Now I get...
                      Timestamp: Wed, 10 Nov 2010 14:40:46 UTC
                      Message: Syntax error
                      Line: 26
                      Char: 1
                      Code: 0
                      URI: file:///C:/Users/sure/Documents/Compass%20User%20Assistance/!SSL!/WebHelp/whskin_tbars.ht m
                      and an error dialog in the skin editor.
                      The back button works, but it did before the change too.
                      Thanks.
                      • 8. Re: Error message in IE when viewing output. whskin_tbars.htm
                        Got to love IE
                        In the skin editor, fill in history.go(-1); in OnClick. Don't include other script. This worked for me on IE8/IE7 with a blank project.
                        Greet,
                        Willam
                        • 9. Re: Error message in IE when viewing output. whskin_tbars.htm
                          stephenure Level 1
                          Now the back button does not do anything.
                          • 10. Re: Error message in IE when viewing output. whskin_tbars.htm
                            stephenure Level 1
                            It seems I accidentally added the back code to the print button and left the code for the back button in the skin.
                            Thanks to W. van Weelden for helping me out.
